Guest wu-style Posted January 11, 2012 Share Posted January 11, 2012 i got a ford escort 1,6 efi 1991 mod, i just both it few days ago.. the cab roof dosent work, when i click the button nothing happens... im trying to find the motor, but cant find it anywhere..? i suspect that the owner before me have removed it. or is it the same motor for the antena..? Ps: sorry the bad english ;P Quote Link to comment Share on other sites More sharing options...
Guest manicman182 Posted January 11, 2012 Share Posted January 11, 2012 Hi wu-stlye, you should find the motor in the boot, left hand side, might be behind a trim panel, rich Quote Link to comment Share on other sites More sharing options...
Guest wu-style Posted January 11, 2012 Share Posted January 11, 2012 hmmmm, i have been there, the only motor i can fint there is for the antenna, is the motor for the cab and the antenna the same...? Quote Link to comment Share on other sites More sharing options...
Guest wu-style Posted January 11, 2012 Share Posted January 11, 2012 never mind i found it =) i was planing to put 12v on it, to see if there is the pump that is broken.... Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted January 11, 2012 Admin Share Posted January 11, 2012 Glad you found it, might be the cog thats broken Quote Link to comment Share on other sites More sharing options...
Guest Knut Inge Sandberg Posted January 16, 2012 Share Posted January 16, 2012 i took the pump oute, and i put 12v on it, the pump seems to run fine =) now i have taken the 2 green relays out, the one green relay serms to be to the antena motor ??? isn it supose to be 2 relays for the pump....? and where can i get this relays...? Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 16, 2012 Share Posted January 16, 2012 some relays for the roof under the dash, drivers side, green/yellow Quote Link to comment Share on other sites More sharing options...
Guest Knut Inge Sandberg Posted January 17, 2012 Share Posted January 17, 2012 ahhh okay but what are the green relays, i have pulled oute then..? one of them is to the anntena motor thats for sure, but the other one..? Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted January 17, 2012 Admin Share Posted January 17, 2012 There are 2 relays at the rear one for roof up and one for room down. If you are not getting power to these then take a look under the drivers footwell for the third one. The antenna relay is usually attached to the ant itself or at the back of the dash above the stereo Paul Quote Link to comment Share on other sites More sharing options...
