Guest baz9707 Posted January 1, 2012 Share Posted January 1, 2012 I have a 1990 ford escort cabriolet mk4 with a cvh mfi 1.6 engine. It had a oil leak and then on the motorway doing 80mph the warning light came on and cut out and for a while started and sounded terrible but did not move now it will not start at all. Do I need a new engine. Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 1, 2012 Share Posted January 1, 2012 did it drain all the oil? does it turn over now? Quote Link to comment Share on other sites More sharing options...
Guest avul Posted January 1, 2012 Share Posted January 1, 2012 have u topped it bak up wiv oil? if u ave no oil or low oil then the tappets will ave no oil in them which means the valve's will not open wen the cam turns, so wont allow gas's in & out of the engine, meanin it wont b able 2 start. as wiv runnin out then it could b terminal & u may have killed it!! check the oil level & top up wiv 10/40 oil, if it turns over but still not start's then get sum1 2 tow u at bout 30mph & put it in2 2nd wiv the ignition turned on & c if it will start, wiv the engine turnin over faster it should fill the tappets up & may start. if it does & it doesn't sound 2 bad sort the oil leak out & c how it goes 4 a while. if not then it could b the top end, but it may b more likely the bottem end as the oil level has run that low, if the oil light comes on then often its 2 late but u can b lucky!!! b'in an older engine is better then a newer engine 2 get away wiv this sort of prob, gd luck & keep us posted regards mark Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted February 20, 2012 Share Posted February 20, 2012 Hi well could not get the engine going and after being on so many exercises recently had no time to do anything. Exept go to Stoke and get a engine complete with gear box and a load of spares for 60 quid. Same 1.6 as the one thats in it, and have just started cleaning it up ready to put in. Currently just took the sump and gear box of and giving them a good scrub and a coat of heat resistant red paint. Quote Link to comment Share on other sites More sharing options...
Guest El87cabi Posted February 20, 2012 Share Posted February 20, 2012 Like your thinking, there's nothing better if you own a cabi than to have spares, lots of them! all the best, el Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted February 20, 2012 Share Posted February 20, 2012 As to spraying the engine block red anyone any thoughts about this so far sprayed the sump and a few bits and bobs but not the main block. Anyone else done this. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 20, 2012 Share Posted February 20, 2012 painted my block red before, still red now a couple of years later, used a spray and not a brush on paint Quote Link to comment Share on other sites More sharing options...
Guest baz9707 Posted February 23, 2012 Share Posted February 23, 2012 Sump and add ond looking good, work holding me back from sorting the rest out. Was thinking of changing the head gasket. While the engine is out. Anyone done this looks pretty simple is there tips on doing this. Also need a new sump plug any ideas. Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted February 24, 2012 Share Posted February 24, 2012 Sump plugs & washer are still available from Fords Quote Link to comment Share on other sites More sharing options...
