Guest paul s Posted December 23, 2011 Share Posted December 23, 2011 can anyone help me my mk4 escort is leaking at front corners were the door glass meets the rubber seals Quote Link to comment Share on other sites More sharing options...
Guest dsharples Posted December 24, 2011 Share Posted December 24, 2011 have you checked if seals are perished or stiff with age therefore not makimng the seal with door closed Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 24, 2011 Share Posted December 24, 2011 is there a gap? as the windows can be ajusted Quote Link to comment Share on other sites More sharing options...
Guest paul s Posted December 25, 2011 Share Posted December 25, 2011 yes there is a gap but i not had car long and been painted just wondered if it needs adjusting Quote Link to comment Share on other sites More sharing options...
Guest paul s Posted December 25, 2011 Share Posted December 25, 2011 and tried adjusting window glass Quote Link to comment Share on other sites More sharing options...
Guest El87cabi Posted January 8, 2012 Share Posted January 8, 2012 If you did the glass no doubt you'll have adjusted the hooks on the roof handles too, if that hasn't worked and the hoods good apart from that i'd either change it for a mohair in the hope it'd solve the problem, i went that route on my old d plate and it worked, or always park your car facing uphill as you seem to get less of a problem from it leaking at that point Quote Link to comment Share on other sites More sharing options...
