Guest tbirdbooboo Posted December 5, 2011 Share Posted December 5, 2011 right so going around roundabouts causes my mk3 mfi 1.6 cab bogg out for a bit - im going to take out the tank and clean it and also want to replace the pump as its loud and sounds like its dicking out all the time. can i use a pump from a xr3i efi mk4 ?????? the pump i have is like a cylinder next to the tank, has inlet at one end then the other has 2 wires and a smaller outlet ( do i need to look for some sort of in-tank bits too ) if its not the same as an efi one then does someone have a correct one for sale lol Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 5, 2011 Share Posted December 5, 2011 EFI is a totally diffrent pump so wont fit. you can buy new ones on ebay for the MFI for around 40 quid, loads on there Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted December 6, 2011 Share Posted December 6, 2011 cool, cheers for that Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted December 6, 2011 Share Posted December 6, 2011 I'd be inclined to check the pink relay which controls the fuel pump. Its common for them to be burnt out. They then become intermitent and will switch the fuel pump off when you corner or hit bumps in the road. Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted December 6, 2011 Share Posted December 6, 2011 ahhh yes the infamous fuel pump relay lol - i remember having that go in my mk2 scirocco gtx pickup lol nightmare. i will replace it anyway an d see how i get on lol Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted December 6, 2011 Share Posted December 6, 2011 dam them relays are expensive ! 40 quid on ebay ! Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 6, 2011 Share Posted December 6, 2011 thats for a new relay tho aint it? if it is its not that bad a price really Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted December 7, 2011 Share Posted December 7, 2011 shame i cant get one from a scrappy but i know there aint no old escorts or similar in the ones near me lol Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted December 7, 2011 Share Posted December 7, 2011 They can be repaired quite easy if you have some soldering experience. Just have to solder the two terminals on the switch contacts. There easy to identify as they will be black with very little solder around them. Quote Link to comment Share on other sites More sharing options...
Guest tbirdbooboo Posted December 12, 2011 Share Posted December 12, 2011 right , i have had a friend check the relay and clean it and stuff and thats working great, saturday we removed the fuel pump and the tank. there was loads of rubbish in both so cleaned them out good and proper and checked all the lines etc. admitidly i did accidently crush a bit of the fuiel line so have had to make a repair with some rubber fuel hose and clamps but its its not leaking. all had been put back in the car and pump works a treat now. went round a roundabout and it bloody boged out again didnt it !!! im watching a full metering injection unit on ebay as im just going to replace everything now until i find the problem, fuel is definately getting to the engine and the spark is good along with new plugs but go round a sharp right and then do a left and the car wants to die so have to let off the throttle for a second and wait . any ideas anyone ??? Quote Link to comment Share on other sites More sharing options...
Guest El87cabi Posted January 8, 2012 Share Posted January 8, 2012 If by bogged down you mean the car loses all power then i'd start jiggling some cables for you go spending any money on parts, look for any plugs and wires that have been reconnected/replaced are damaged, could just be you have an earthing fault thats making the car cut out. Quote Link to comment Share on other sites More sharing options...
