Matt White
Guest no1birdman
Guest no1birdman
anyone done matt white, mate wants me to spray is matt white, done every colour before but not matt white, useing one pack synthetic paint, I said it would look just like white primer but if that what he wants.Just a matter of adding gloss reducer to white paint.
Guest Alanman
My mate painted his BMW matt white and its not too bad to look after as far as I know.
He painted his with tins (a lot of) Proffesional Graffiti Paint.
He uses it everyday and comes clean pritty easy but any stubbon marks he'll just paint it again. lol.
Guest no1birdman
looks nice, its easy to clean if you do not use white primer, you just have the shine taken out of the paint. I only use synthetic one pack so do not know about how you would do it in 2 pack.Did mine in satin black but do not like it much will do it matt black then if matt white looks good will try that. Going to have a look up of that graffiti paint it loooks nice
Edited by no1birdman
Guest no1birdman
hi, did not realise it was a rattle can, no problem i sprayed the bottom half of my cab once with chrome rattle can from plasticote it came out great but only lasts for about 4 months then had to keep doing but 2 tins did it after the first 6 cans.You could spray it with a couple of litres of white synthetic for 20pounds then go over with this stuff, It seems rattle cans have come a long way the last couple of years, I think people who have never sprayed knock them but you can get a good finish dead easy doing a matt colour.That is cheap spray painting 3 tins over a litre of paint so 10 tins over 3 litres easily enough to do a cab, I did mine with 2 litres satin black over yellow/chrome.
Guest Alanman
Rattle cans can be poor, but this stuff is made for grafitiing so it covers anything. He had no problems with coverage and no reactions anywhere. It's been done now about 10 months and still looks as good now.
Guest no1birdman
hi, might try that paint on my own car, just do the sides and spoilers and leave bonnet and boot black, do not know what it will look like but will have a go.
Guest no1birdman
Hi, decided after looking at that bmw to do mine all matt white, just ordered the white primer of my mate, so free, will post pic up when done, do not know whether to use that rattle can paint for finish or just get some gloss white with the shine taken off, Did not like the satin black look.
Guest no1birdman
Hi, yes it does, just doing today the botom half of car chrome, plasticote stuff till weather warms a bit then going to do all matt white.Wife did not like it all black.
  • 3 weeks later...
Guest no1birdman
just got matt white primer and matt white top coat, it looks hard to spray the white topcoat over the primer as u cannot see much difference under lights, think will wait till after xmas and do it at mates spray shop, the whitest white i could get was ral9010 pure white.
  • 1 month later...
Guest carlman
Nearly finished it now in matte white, black roof but which colour wheels black or white and do not know wether to detail in black or red.Its The whitest white I have seen,Ended up spraying it in 1pack synthetic enamel has i get it for nothing.
Guest no1birdman
My name keeps changing,Sprayed wheels white, it looks cool befor cool said it was cool to look cool. I must say matt white and white wheels is a deff improvement on satin black
Guest no1birdman
one of the easiest paint jobs ever done, the matte white covers everything and does not show any imperfections in the prep, sprayed it at 70psi pressure with a massive compressor 8.5hp, but could do it easily with a small cheap aldi like compressor if done 1 panel at a time.
Guest no1birdman
i know, either covering up my welding, letting air into diesel engine or just had a few vents over and stuck them on, makes it a bit different, had it 20 years, oil sprayed underneath every few months, no rust, diesel tank in boot, easier to do brake pipes and easier to bleed diesel pump now.does easy 50mpg knocking about a lot more on a good run
