Guest pleco Posted November 13, 2011 Share Posted November 13, 2011 Hi im new to having a cabriolet and the one i got the tension wire is about an inch up the roof at the back with two black tabs on the wire how does it actually fit as the previous owner fitted the roof and also where does the little brown wire go on the battery thanks Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 13, 2011 Share Posted November 13, 2011 the wire runs around the back and has a threaded end both sides, remove the rear speaker pods and you will see the ends of them and the nut to loosen. brown=negative. assuming its a mk4 aswell Quote Link to comment Share on other sites More sharing options...
Guest pleco Posted November 14, 2011 Share Posted November 14, 2011 hi thanks for the reply its a mk3 and the wire is in plain sight does it feed through a channel in the hood or pull the hood down into the channel and the wire is hidden i will be fitting a new wire when i work out how its fitted correctly Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 14, 2011 Share Posted November 14, 2011 it doesnt go through a channel in the roof, it should tighten up and pull under the lip of the car body, it should not be visable at all, its quite a job to get fully under the lip. it only feeds inside the roof by the rear side windows, be carefull with the new wire though, they like to snap! Quote Link to comment Share on other sites More sharing options...
Guest pleco Posted November 14, 2011 Share Posted November 14, 2011 ok nice one thanks any ideas where the thin brown wire goes on the battery is it positive or negative Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 14, 2011 Share Posted November 14, 2011 should be negative mate Quote Link to comment Share on other sites More sharing options...
Guest dicko601 Posted December 11, 2011 Share Posted December 11, 2011 hi ginge, just noticed this topic on the roof cable, ive just put a new 1 on this weekend, (by the way, car hoods northern £25, fords £18) and its fitted nicely, but below the rear window you can still see the cable, ok round the corners and sides, any ideas how to hide the rest of it ? Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 11, 2011 Share Posted December 11, 2011 hi mate, you gotta slowly tease it under, i used a screwdriver with a cloth over the end of it, push down and up and it should start to go, dont over tighten the cable at both ends while doing it as i found it harder to work the cable under Quote Link to comment Share on other sites More sharing options...
Guest dicko601 Posted December 11, 2011 Share Posted December 11, 2011 Nice 1 m8, just had a go with a good wide screwdriver, cables gone under now, Looks loads better, roofs as tight as a drum, cheers,,,, Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 11, 2011 Share Posted December 11, 2011 good stuff mate, atleast the cable didnt snap! Quote Link to comment Share on other sites More sharing options...
Guest Bullfighter Posted January 29, 2012 Share Posted January 29, 2012 Thanks for the tips Gingerman, i must replace my cable to be able to put on loops for the hoodcover, reading your tips it seems to be able to do it by my self. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 1, 2012 Share Posted February 1, 2012 Quote Link to comment Share on other sites More sharing options...
