Guest gavin1984 Posted September 15, 2011 Share Posted September 15, 2011 hi wonder if any one could help me, just replaced to wishbones tracker end and had tracking done but my tyres are still scrubbing out changed them last week and bald on outside already can hearsome clunking when i pull off or brake and when turning, any ideas? Link to comment Share on other sites More sharing options...
Guest avul Posted September 15, 2011 Share Posted September 15, 2011 hi gavin even tho u ave 1984 next 2 ur name i take it ur car is not a mk3? but in fact a mk5 or 6? u say wishbone tracker end? but i think u mean front wishbone outer ball joint? if thats wat u replaced i'm affraid u wasted the money on those ball joint's & u should of just got the complete front wishbone as these r a really commen prob wiv the mk5-on escort's & also the mondeo! wat always goes on these is the rear rubber joint & wen u corner, brake & accellerate the bush flex's & as the rubber start's 2 rip away frm the metal of the bush & get's older wiv time the rust start's 2 get in aswell & it just worsen's! it also get's worse a lot quicker on a lowered car!! as u say it's knockin on pullin off, brakin & cornering i'd say it's def the front rear rubber joint's on both front wishbone's & the garage that tracked ur car should of noticed them really, thats if u took it 2 a gd garage??? if it's killed the front tyre's that quick i wouldn't drive it untill u get the front wishbones replaced, u should b able 2 get them front a gd motor factor's 4 bout £20-25 each, if u really wat 2 spand the money u can get a full front repair kit wiv polly bushes but they r expensive!!! hope this help u out? regards mark any other question's just ask m8. Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted September 15, 2011 Share Posted September 15, 2011 hi mate yeah its a mk6, 1984 was year i was born just plain gavin was taken so had to put that on end lol, yeah changed both the wish bones and the track rod end on pass side, but have noticed the rubber pulling out of them already would anything else cause it do you think? Link to comment Share on other sites More sharing options...
Guest avul Posted September 18, 2011 Share Posted September 18, 2011 so u say that u have replaced both front wishbones but the rubbers r startin 2 rip out, how long ago did u replace them??? if they r cheap 1's u myt only get a yr at best if its a daily driver & dependin on wat the roads r like round ur way pothole's, speedbump's etc. if the wishbones r ok & the trackin is ok, then u may have a bigger prob, has the car bin kurbed? if so the shock/ inner wing or steerin arm could b bent. sorry it took a while bin a bit busy m8, let us know bout wats goin on wiv wat u know & i'l c if i can help ya more regards mark Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted September 18, 2011 Share Posted September 18, 2011 hi mate, yeah replaced them both about 6 weeks ago rubber is starting to pull out of drivers side 1 already roads are bad around me but doubt it would do that would it? not been curbed or anything but was speaking to a guy who does cars and he wouldnt recomend the place i had them from as he thinks they are refurb1's. will have to book it into my local garage i think as only know how to do the basics myself lol Link to comment Share on other sites More sharing options...
Guest avul Posted September 23, 2011 Share Posted September 23, 2011 sorry 4 the long delay m8, not able 2 get on here much at the mo as just moved out of my house & at the inlaws 4 a few wks..... still can on now & again lol yea keep us posted m8 Link to comment Share on other sites More sharing options...
Guest shaun Posted September 27, 2011 Share Posted September 27, 2011 When you changed the arms did you put 4 new bolts in as well? Got told by someone who works in Ford to change them for new aswell as they wear Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted October 6, 2011 Share Posted October 6, 2011 i did on 1side but they keep coming loose all the time, still waiting for my mate to have a look at it, Link to comment Share on other sites More sharing options...
Guest avul Posted October 6, 2011 Share Posted October 6, 2011 keep us posted gav, u may need it put on a proper machine 2 check the caster,camber etc Link to comment Share on other sites More sharing options...
