Guest gavin1984 Posted September 15, 2011 Share Posted September 15, 2011 hi every one, having a bit of trouble with my roof recently it wont go down using the button but if i put it down manualy by turning the thing in the boot when its down then i turn it back the other way the roof just goes up onits own.can also hear the motor running then i start the car to....any ideas??? Quote Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted September 18, 2011 Share Posted September 18, 2011 any 1????? Quote Link to comment Share on other sites More sharing options...
allblue Posted September 18, 2011 Share Posted September 18, 2011 Hiya, Does your pump have a plastic black outer cylinder casing? It may likley be the plastic cog inside the unit which has failed. Common problem involving mk6's with these pumps. Quote Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted September 18, 2011 Share Posted September 18, 2011 clear casing, do they come apart easy enough to check? Quote Link to comment Share on other sites More sharing options...
Guest garyc Posted September 19, 2011 Share Posted September 19, 2011 hi gavin1984 if you need a pump for your car let me no as i have one for sale gary Quote Link to comment Share on other sites More sharing options...
