Guest JKE Posted August 24, 2011 Share Posted August 24, 2011 Hi all I have owned my cabby for a couple of months now and am pulling my hair out! I bought it from an auction and have no history. It jerks badly when I drive at constant speed and when the engine is cold the engine races. I have heard this is a common problem with the EFI. The plugs, HT leads and coil pack have been changed and I have tried to source a throttle position sensor to elimate this but it would seem that Ford have discontinued the part. Not sure where to go now with it.....please has anyone any ideas? Jen Link to comment Share on other sites More sharing options...
ianxr3i Posted August 24, 2011 Share Posted August 24, 2011 You could try Burton power products - http://www.burtonpower.com They seem to get hold of discontinued ford stock. I have used them for a few parts for my EFi cabriolet Link to comment Share on other sites More sharing options...
Guest JKE Posted August 24, 2011 Share Posted August 24, 2011 Thanks I will look at their website, my husband uses them for his MK1 Cortina regards Jen You could try Burton power products - http://www.burtonpower.com They seem to get hold of discontinued ford stock. I have used them for a few parts for my EFi cabriolet Link to comment Share on other sites More sharing options...
Guest corrie Posted August 25, 2011 Share Posted August 25, 2011 hi i had this problem with mine when i first got it, and here is what i done, i had the idle speed and mixture set up also i had the fuel pressure regulator set up, in addition to this i used some air intake cleaner sprayed into the throttle housing as these engines have a tendency to coke up badly. mine now runs absolutely spot on now. you can be constantly trying to chase these faults by changing lots of different parts without remedy. i also reset the ecu and taught it how to drive properly to my driving style. if you want anymore info just inbox me. Link to comment Share on other sites More sharing options...
Guest JKE Posted September 1, 2011 Share Posted September 1, 2011 Thanks for the advice, our local car parts shop managed to get me a throttle position sensor which my husband fitted last night and my cabby now runs like a dream..........so happy Link to comment Share on other sites More sharing options...
