Guest Ant Posted August 10, 2011 Share Posted August 10, 2011 Hi guys, I replaced the thermostat in my cabby as the old one was faulty. Now since then my water level drops everytime i drive it??? I fill it to the max mark and go out for a 20min drive and it will drop to half way?? and it will keep going down unless i top it up? I have no obvious signs of leaks and there is no water in my oil so where is it going???? It only drains when the engine is running? Any help much appreciated Regards Ant Link to comment Share on other sites More sharing options...
Admin Paul Posted August 10, 2011 Admin Share Posted August 10, 2011 Water pump leaking? Link to comment Share on other sites More sharing options...
Guest Ant Posted August 10, 2011 Share Posted August 10, 2011 Water pump leaking? not 100% sure mate. Ive left it running and layed on the floor looking under the car for about 10mins but no drops or anything? Link to comment Share on other sites More sharing options...
Guest Savage Posted August 10, 2011 Share Posted August 10, 2011 I think it's really thirsty engine fairies. Nobody knows how to stop these water stealing angels, all I know is that should you run out of water for them to drink, they start eating your engine parts until it ceases to run. They truly are the nastiest of all the known fairy family. At least the tooth fairy leaves you money. Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 10, 2011 Share Posted August 10, 2011 Sounds a stupid question but did you make sure the thermostat was fitted the correct way round with the air release hole facing upwards. If not the engine wont bleed itself of air meaning you have air pockets causing water level to vary and also hotspots where the fluid boils. this will release water vapour from the header tank cap as the system over pressurises. Just an idea Link to comment Share on other sites More sharing options...
Guest Savage Posted August 10, 2011 Share Posted August 10, 2011 Ok, there's a grown up answer. Lee's seems more plausible. Link to comment Share on other sites More sharing options...
Guest Ant Posted August 11, 2011 Share Posted August 11, 2011 Your thirsty engine fairies made me laugh dude lol!!! I nearly went out to the car to shout at those greedy greedy fairies haha!! Cheers Lee i shall take it out again and double check just to make sure? Maybe that is the problem? Hope so anyways my poor poor cabby Dont want her to overheat and die!! Link to comment Share on other sites More sharing options...
