Cards...
Guest Savage
Guest Savage
My door cards looked pants...
Front before...
Front now drying and needs another coat (waiting now so hence the topic)...
Back before...
Back after...
Got the trim bits in white drying off now also :smile:
Thought I'd share what I'm up to as I'm bored of watching paint dry.
Guest Savage
Looking at the pics together I should mention front and back are the same colour, just bad light and phone camera making them look very very different.
Guest Savage
Still a work in progress. Haven't got a final happy face on about them yet. Sorting out the door pockets (purple with white trim) before I lacquer / seal the whites. I quite like them but theres a something niggling me that is making me uncertain. Car looks like it's changing to a black and yellow theme soon so may all be a waste of time as I'll be changing again.
Still, passes the time whilst waiting for work to appear.
  • 4 weeks later...
Guest derrick
Front before...
Back before...
Back after...
hi savage can you tell me what you used to paint the panels with as fabric is frayed and coming away from the panels is it just spray paint or fabric paint, the rear ones of mine are in a mess whereas the front are okay so i might paint mine black. any help appreciated
Guest Savage
The rear cards were simple enough as the fabric pretty much fell off. All I needed to do was sand the left over bits to get them flush, bog standard primer spray, then went over with colour matched spray. If you're going black, any black spray will do.
The front cards were a bit trickier in that the fabric wouldn't come off so needed to spray over the fabric. Vinyl primer (about £4 from b&q) then I used the same spray as I did with the rears.
Only down side is that the front cards feel a little "prickly" when you rest bare arms on them but the other option is flocking and that gets expensive quickly.
hi sav, hows u m8?
my opinion is it's a shame u sprayed the top half of the front's as i think the rear's look really gd & wiv that u could easily spray the bottem wen the change cum's & leave the top black, which if u do go black over yellow i think will look gd in the car but not over the top, hard 1 to get ryt if ur goin a bit brave wiv a colour 2 not go over the top,balancin act hey!!!! keep the pic's cumin m8 & hope u get the outside of the car done soon :salut_gb:
regards mark
Guest Savage
Hair dryer. Genius. Didn't think of it mate. I've got one half of the car destickered and glued (using hair dryer!!!) still seeing if I can pull something out the bag sponsorship wise.
Looks like the front end may be staying purple with just the rear changing to yellow. But yes, I went over the masking which is why the top went purple. New attempt at the cards likely to be purple tops with amber / yellow tie dye effect bottoms. I'll slap some pics up once done.
Edited by Savage
Guest derrick
cheers for that savage as i said my rear cards are mingin and the frot while they are in an ok condition i might try and peel off the material and see how that goes but i think ill try it first on a few from a sceap yard to get it right as another member said using a hair dryer i kight try that on the material to see if it loosens the glue a little and ill post before and after pics too im kepping the bottoms black and top grey/white ive a body shop across the road from me so i may well get them to paint them all new and shiny black or just do it my self lol
Hair dryer. Genius. Didn't think of it mate. I've got one half of the car destickered and glued (using hair dryer!!!) now that did make me laugh :laugh: :laugh: :laugh:
u use a hair drier 4 the sticker's but didn't think 2 use it 4 the clue on the door cards :blush::tongue:
nice 1 m8, lookin gd
mind u i cant talk i answered ur other post b4 i answered this 1 i 1st wrote on :blush::rolleyes:
mark
