Guest gavin1984 Posted July 26, 2011 Share Posted July 26, 2011 hi was wondering if any 1 could give me advice on why my car shoots the the left when i put my foot down an back the the right when i lay off, would tracking being out make it do that, changedthe drivers side wishbone the other day would that have anything to do with it? Link to comment Share on other sites More sharing options...
Guest Savage Posted July 26, 2011 Share Posted July 26, 2011 One of mine used to do that and turned out Both front and rear wishbones knackered. Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted July 27, 2011 Share Posted July 27, 2011 One of mine used to do that and turned out Both front and rear wishbones knackered. didnt know there were wishbones on the rear but then im no mechanic are they the same shape as the front ones? Link to comment Share on other sites More sharing options...
Guest Savage Posted July 28, 2011 Share Posted July 28, 2011 Havent a clue to be honest. I know the front was shot, needed a batch of other things doing as well so just gave the car to someone considerably more technical than me and he said front and rear were dead. Quite scary having to fight the steering on motorway runs if I remember correctly. Link to comment Share on other sites More sharing options...
Guest avul Posted July 28, 2011 Share Posted July 28, 2011 hi gavin just ad a look on ur profile & take it frm the interior its a mk6, only saw the 1's wiv the wirin prob's. the mk3&4's ad track control arm's front & independent rear suspension which use's wishbone's the mk5&6's ad wishbone's front & a beam axle on the rear, so the rear doesn't use wishbone's on these model's. if u changed 1 front 1, the chance's r the other is shot 2 & it's best 2 chance these as a pair most of the time, also u will need 2 get the trackin set up after u do pretty much any thin 2 the suspension wen u change 4 a new part, its very unlikely that u will get this prob frm the rear unless the rear shock's r totally shot but i did ave this sort of prob on my mk3, the prob wiv that was goin down the road & wen i hit a bump it made the rear end skip about, not nice at 80mph on the m11, made the cheek's nip up a bit!!! lol, new shock's & that was sorted. wiv the front of the mk5&6 the prob wiv the wishbone's is the rubber pivitt joint's rip out, (witch u prob noticed on the 1 u replaced) & wen u brake & accelarate the wishbone's move about witch alter's the trackin dramatically & the car will pull all over the place & can b very dangerous, but wiv the trackin if that's not set up afterward's properly u will scrub out ur tyre's. hope this help's, if u need anymore advice just ask. regards mark Link to comment Share on other sites More sharing options...
Guest Savage Posted July 28, 2011 Share Posted July 28, 2011 Erm, yep. What he said ^. Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted July 28, 2011 Share Posted July 28, 2011 hi gavin just ad a look on ur profile & take it frm the interior its a mk6, only saw the 1's wiv the wirin prob's. the mk3&4's ad track control arm's front & independent rear suspension which use's wishbone's the mk5&6's ad wishbone's front & a beam axle on the rear, so the rear doesn't use wishbone's on these model's. if u changed 1 front 1, the chance's r the other is shot 2 & it's best 2 chance these as a pair most of the time, also u will need 2 get the trackin set up after u do pretty much any thin 2 the suspension wen u change 4 a new part, its very unlikely that u will get this prob frm the rear unless the rear shock's r totally shot but i did ave this sort of prob on my mk3, the prob wiv that was goin down the road & wen i hit a bump it made the rear end skip about, not nice at 80mph on the m11, made the cheek's nip up a bit!!! lol, new shock's & that was sorted. wiv the front of the mk5&6 the prob wiv the wishbone's is the rubber pivitt joint's rip out, (witch u prob noticed on the 1 u replaced) & wen u brake & accelarate the wishbone's move about witch alter's the trackin dramatically & the car will pull all over the place & can b very dangerous, but wiv the trackin if that's not set up afterward's properly u will scrub out ur tyre's. hope this help's, if u need anymore advice just ask. regards mark hi mate thanks for the great advice it is a mk6 , yeah did notice the rubber pivitt pulled out thats the reason i changed it, and tyres are scrubbing out only changed the to front last month and got to do again 2moz but will have themsort the tracking out the same time, yeah is very scary when on the motorway and you dont have to turn the blody wheel the change lanes very scary lol Link to comment Share on other sites More sharing options...
Guest avul Posted July 29, 2011 Share Posted July 29, 2011 no probs gavin r u goin 2 do the other wishbone b4 u get the trackin done? if not get them 2 check the old 1 so u know but b warned, 1 side wishbone is easier 2 c if its ripped & the other is really hard as 1 wishbone has the rubber pivitt joint 1 way up & the other side r pressed in the wishbone the other way up & can b a lot harder 2 c if they r actually ripped!!! yea bet it is fun 2 drive but in the wrong way keep us posted bout it m8, we dont want sum1 avin a big of on a roundabout just cos of a bloody bit of rubber!!! regards mark here savage that me laugh at ur comment, hope ur still enjoyin urs wiv the new big power m8? Link to comment Share on other sites More sharing options...
Guest Savage Posted July 29, 2011 Share Posted July 29, 2011 It's great fun but the shocks are fecked so gets a little twitchy on bends at speed. Link to comment Share on other sites More sharing options...
Guest avul Posted July 30, 2011 Share Posted July 30, 2011 try & get that done as soon as ya can m8, 1: b a lot saver, 2: b a hell of a lot more fun well done m8 & ave fun wiv it mark Link to comment Share on other sites More sharing options...
Guest Savage Posted July 30, 2011 Share Posted July 30, 2011 I kept the standard shocks on when we lowered it but they're now toast so getting them changed over start of Sept... MOT, shocks, couple niggly bits, and raising it up. 100mm is too low a drop, going to go to 60's. Link to comment Share on other sites More sharing options...
Guest avul Posted July 30, 2011 Share Posted July 30, 2011 hell m8 that is lloooowwwwww must b a bugger on the speed bumps??? u gonna repaint it or leave it as it is? think 4 all u'v done would look real nice. Link to comment Share on other sites More sharing options...
Guest Savage Posted July 30, 2011 Share Posted July 30, 2011 I might end up starting a project thread... It's getting a wrap before the new year, just waiting for the OK on design from a sponsor. Link to comment Share on other sites More sharing options...
Guest avul Posted August 1, 2011 Share Posted August 1, 2011 well done m8, gd on ya. yea will look gd, take it u got a design. yea get a thread goin m8, pics frm the start aswell, b gd 2 c the build up mark Link to comment Share on other sites More sharing options...
Guest gavin1984 Posted August 4, 2011 Share Posted August 4, 2011 no probs gavin r u goin 2 do the other wishbone b4 u get the trackin done? if not get them 2 check the old 1 so u know but b warned, 1 side wishbone is easier 2 c if its ripped & the other is really hard as 1 wishbone has the rubber pivitt joint 1 way up & the other side r pressed in the wishbone the other way up & can b a lot harder 2 c if they r actually ripped!!! yea bet it is fun 2 drive but in the wrong way keep us posted bout it m8, we dont want sum1 avin a big of on a roundabout just cos of a bloody bit of rubber!!! regards mark here savage that me laugh at ur comment, hope ur still enjoyin urs wiv the new big power m8? yeah change other wishbone and noticed tracker arm ball joint had popped out to so changed that same time cars finaly going straight lol Link to comment Share on other sites More sharing options...
Guest Savage Posted August 4, 2011 Share Posted August 4, 2011 Glad it's running straight for you buddy. Link to comment Share on other sites More sharing options...
Guest avul Posted August 4, 2011 Share Posted August 4, 2011 well done gavin, glad u got it all sorted & now its nice & safe, u can now enjoy a proper drive regards mark Link to comment Share on other sites More sharing options...
