Guest fimbo xr3i Posted July 1, 2011 Share Posted July 1, 2011 just got a complete roof in fantastic condition to replace knackered one.does anyone have any info or instructions how to fit,i have looked on site but can only find mk5/6 instructions.many thanks Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 1, 2011 Share Posted July 1, 2011 its easy mate, remove rear speaker pods and cards, undo the roof retainting cable, (behind speaker pods, you will see it). then just undo the three 17mm bolts on both sides, and also the lifting struts, then just lift the roof off. same to re-fit, just the retaining cable can be a sod to get back in the groove properly, i used a screwdriver to prize it back in gently, and be carefull, the cable likes to snap if you tighten it too much. where abouts are you? i will give you a hand if your not far Quote Link to comment Share on other sites More sharing options...
Guest fimbo xr3i Posted July 1, 2011 Share Posted July 1, 2011 cheers buddy will give it ago on mon Quote Link to comment Share on other sites More sharing options...
Guest fimbo xr3i Posted July 1, 2011 Share Posted July 1, 2011 cheers buddy will give it ago on mon am in cleethorpes humberside mate,bit of a distance from you i think but cheers for offer mate Quote Link to comment Share on other sites More sharing options...
Guest fimbo xr3i Posted July 13, 2011 Share Posted July 13, 2011 finally got the roof fitted yesterday was lot easier than i thought and took about a hour,looks fantastic n very happy with it Quote Link to comment Share on other sites More sharing options...
