Guest Rustler Posted June 30, 2011 Share Posted June 30, 2011 Have just fitted a pair of late MK5 RS2000 headlamps to my '92 MK5 129ps XR3i cabby..They are the elect' adjustable type but I'll use them without this feature........anybody know the set up measurement/dimensions?..... ie..with the car a set distance from a wall ,what should the light pattern be....how high ? off set ? etc,etc, Link to comment Share on other sites More sharing options...
Guest tony.rose Posted June 30, 2011 Share Posted June 30, 2011 Would like to know this for my 86 MK4, as I have just put my headlamps back in. Link to comment Share on other sites More sharing options...
Guest Rustler Posted June 30, 2011 Share Posted June 30, 2011 Would like to know this for my 86 MK4, as I have just put my headlamps back in. Hi Tony.. Yeah... We managed to covert.. AND.. align the RH drive lamps on our SORENTO 4x4 and pass the "CONTROL TECKNIK" BUT.. had to purchase a good S/H pair of RS2000's from Germany for the cabby..Might try the same measurements I used on 4x4 Did you buy new or S/H LHD units for your MK4?..........Lets hope someone on here comes up with the correct info.. ................. ....... ........ Link to comment Share on other sites More sharing options...
Guest avul Posted June 30, 2011 Share Posted June 30, 2011 hi guys, i dont have any dimensions or measurements but all i do is take the car out 2 a long straight quite country road wiv no light's take a touch so u can c wat ur doin & a jumper or sumthin u can cover 1 light wiv. u should pull close 2 the side of the road & u should c where the beam is! u need 2 set the level just below the level of the road in the far distance & the kick off on the edge of the curb/grass verge & they should b set fairly close. the kick off is important as this is 2 c higher up the near side 2 c more ie: perdestrian's ect & this can b seen but its is important 2 do 1 at a time wiv 1 light covered so u dont mix up the beam patern, but set both kick off's at the near side curb/grass verge. i know its not exact but its just as gd & u shouldn't get flashed , i dont & the last time i set my own car up like this it didn't fail the mot either, hope this is helpful 4 any1 who needs 2 set up there light the last lights i set up this way was on my brothers mondeo wiv aftermarket reflector type lights regards mark Link to comment Share on other sites More sharing options...
Guest Rustler Posted July 1, 2011 Share Posted July 1, 2011 Well... Thanks avul.. I recon thats a really great idea...just so simple and effective....I think some of us 'specially me, want to use torque wrench just to put a 2BA screw in place..........we hardly ever think "OUTSIDE OF THE BOX" ....so "Good On You M8" I'm sure your method will do ME FINE, and get me through this "French MOT".........FANTASTIC!!!!!! Link to comment Share on other sites More sharing options...
Guest tony.rose Posted July 1, 2011 Share Posted July 1, 2011 Yeh thanks for that info Avul, I will give it a try, the French think we the anglais are all mad anyway lol No mine is a french left hand drive so no need to change headlights on the mk4. Link to comment Share on other sites More sharing options...
Guest avul Posted July 1, 2011 Share Posted July 1, 2011 thats fine fella's, i do usually think out side the box yea it should b fairly close, it normally wrks 4 me, but dont 4get 2 cover the 1 ur not adjustin so u can c the beam pattern gd luck regards mark Link to comment Share on other sites More sharing options...
