Guest shaneb677 Posted June 3, 2011 Share Posted June 3, 2011 ok i want to remove my rear shocks and springs on my mk6 just want to no if this is correct before i go ahead.......... #1 REMOVE THE BOTTOM BOLT ON THE BOTTOM OF THE REAR SHOCK #2 REMOVE THE THREE BOLTS ON THE TOP OF THE SHOCK #3 THEN PULL THE BOTTOM OF THE SHOCK OUT #4 THEN THE SAME IN OPPOSITE ORDER WHEN FITTING NEW Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 3, 2011 Share Posted June 3, 2011 if it was me id undo the top nuts first then the bottom, doubt it matters tho, just the way id do it Quote Link to comment Share on other sites More sharing options...
Guest avul Posted June 4, 2011 Share Posted June 4, 2011 put the car up on axle stand's, do 1 side at a time & ave ur jack under the hub of the side ur doin so u can let the axle down 2 take out the shock & use the jack 2 put it bak in2 place. undo the bottom nut & bolt & remove it then take out the 2 bolt's that hold the shock the rear inner wing & take out the shock & spring 2 gether, now wiv the shock out undo the top nut & bolt (u dont need a spring compressor 4 the rear spring 2 compress it) but hold the spring down & take out the bolt & then just take the spring & shock apart, job done & then the same as in reverse 2 put bak 2gether, make sure that the dust cover's r in gd order as these r the commen cause 4 the rear shock 2 leak on the mk5,6 & 7 as the dust & dirt get in & kill the seal's, but they r an easy job 2 replace, it's just a shame that all moden cars ein't as easy these day's. Quote Link to comment Share on other sites More sharing options...
