Guest JordanNeltharionGray Posted May 30, 2011 Share Posted May 30, 2011 travelling down the road and all the oil just bled out, i stopped and refilled only for it to come pouring out the other end, i looked underneath but no obvious holes in sump ect.... any sugestions??? Quote Link to comment Share on other sites More sharing options...
Guest spenny Posted May 30, 2011 Share Posted May 30, 2011 Check the oil return pipes ..... Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 31, 2011 Share Posted May 31, 2011 Sump plug has come out. If you filling it with oil and its pouring out when the engine isn't running it can only be something in sump area. Well unless your putting the oil in the wrong place lol. If your engines ran that low on oil its probably nackered now Quote Link to comment Share on other sites More sharing options...
Guest JordanNeltharionGray Posted May 31, 2011 Share Posted May 31, 2011 ty guys, im gonna have the engine re-maufactured when i have the funds and return it to pretty myh standard with a few minor changes, anything i need to look out for ??? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 31, 2011 Share Posted May 31, 2011 Just make sure they include to replace the oil pump, water pump, tensioners, tappets etc. Some don't but then ask you later for more. Its best to replace them. You then know you wont have to replace them later which will cost more and may damage the new engine. You wouldn't beleave how many firms clean the components and only replace the rings,bearings and gaskets. It'll give you a engine that sounds and looks like a new unit but will only last a 1/4 of the miles at best. Only other thing is to be aware you may have a serious fault with your current engine that means its no good for re-manufacture Quote Link to comment Share on other sites More sharing options...
Guest JordanNeltharionGray Posted June 1, 2011 Share Posted June 1, 2011 does this sound like a good deal "What does the remanufacture consist of? The engine is stripped to bare component and put into a high pressure cylindrical wash at high temperature with cleansing chemicals, this removes all carbon deposits and debris from previous failures and brings component back to a “bright” metal.From this stage the Cylinder Block is re-honed and or re-bored. The Pistons and or Rings are then changed, Connecting Rods are then re-honed. The Crankshaft is then reground and or polished. After this the main and big end bearing shells are replaced to suit the size of the journal and the Oil pump reconditioned.The Cylinder Head is stripped down and checked for wear, cracks and for trueness then pressure tested and refaced as necessary. Valve guides are then checked for wear and replaced as necessary, the valve seats are then. New/Refaced valves are then lapped into the head then vacuum tested. We then reface the valves followers as necessary. The Camshaft is then checked for wear and replaced as necessary. The engine is then reassembled with new gaskets and seals." Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 1, 2011 Share Posted June 1, 2011 Sounds ok. Not sure what they mean by valve followers refaced. They need replacing unless there prity new. Allow extra for new water pump. Thermostat. wise to replace these just for peace of mind. Just make sure they do all the work shown lol. Quote Link to comment Share on other sites More sharing options...
Guest gavintwopies Posted June 12, 2011 Share Posted June 12, 2011 How much does that lot cost to have done out of curiousity??? Quote Link to comment Share on other sites More sharing options...
Guest JordanNeltharionGray Posted June 17, 2011 Share Posted June 17, 2011 How much does that lot cost to have done out of curiousity??? well i live in leicester, and they come and collect it, remove the block, do all the work, put it back in, deliver the car back to my door all for £1k Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 17, 2011 Share Posted June 17, 2011 not bad for a grand, Quote Link to comment Share on other sites More sharing options...
