Guest hbjseries1 Posted May 26, 2011 Share Posted May 26, 2011 hi im harry, im 17 and im having trouble with my seires 1 i purchased 2 days ago. i put the key in and theres nothing. no lights on the dash no crank nothing. ive cleaned the earths and put them back but still nothing any ideas thanks Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 26, 2011 Share Posted May 26, 2011 might sound stupid lol but is the battery fooked? Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted May 26, 2011 Share Posted May 26, 2011 erm it started my freinds r5 before and after we tried it lol, but thanks anyway Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 26, 2011 Share Posted May 26, 2011 Check the fuses and also if it has a immobiliser make sure its working Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted May 26, 2011 Share Posted May 26, 2011 Check the fuses and also if it has a immobiliser make sure its working ok im gettin some fuses but it doesnt look like mine has a immobiliser, the thing is the ignition barrel no immobiliser hole at all. nd would the lights still come on if it had the immobiliser? Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted May 26, 2011 Share Posted May 26, 2011 sorry my mistake the car only had a ignition barrlel no immobiliser hole and the lights on the dash or summin should light up still shouldnt it Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 27, 2011 Share Posted May 27, 2011 not all immobilisers are visible. Most are now plib activated with the alarm. On mine I can turn the lights on but thats it. No electrics will work unless I press the remote. A blown fuse that powers all the lighting and dash will mean nothing will work. Ideally you need a multimeter to check at various points were power is. Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted May 28, 2011 Share Posted May 28, 2011 ok thanks il get a multimeter and give it a shot Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted June 4, 2011 Share Posted June 4, 2011 hi i have a update, i was told their is no immobilizer from the previous owners and wen i put the terminals on the batterys nuffin happens still but i used 2 cables goin from the positive and negative terminal with the battery on, to the empty slot in the key hole shown in the pic and and the other wire to where the black and yellow wire bellow is and the engine started ticking over, and also when i touch the cable on the empty slot above and wiv the black cable on the left the dash lights come on any ideas? Quote Link to comment Share on other sites More sharing options...
Guest hbjseries1 Posted June 4, 2011 Share Posted June 4, 2011 i meant also when i touch the cable on the empty slot below and use the other cable wiv the black cable on the left the dash lights come on any ideas? Quote Link to comment Share on other sites More sharing options...
