Guest Peterdyfed Posted April 28, 2011 Share Posted April 28, 2011 My Mk4 escort cabbie roof won't work anymore.The car was standing for over a year and when I went to open the roof it opened halfway then stopped. I think the problem is electrical. Where are the fuses and relays located so I can check them? Cheers. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 28, 2011 Share Posted April 28, 2011 you got 2 relay's in the boot which are green and a silver isolator fuse and 2 in front o/s footwell 1 yellow and 1 green.not sure if any other fuses are in there Quote Link to comment Share on other sites More sharing options...
welshlad Posted April 28, 2011 Share Posted April 28, 2011 IT COULD BE THE SWITCH AS MINE IS DODGY AND ONLY WORKS NOW AND THEN Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 28, 2011 Share Posted April 28, 2011 swap the switch for a window one, quick way to elimanate it Quote Link to comment Share on other sites More sharing options...
Guest flashtec Posted May 16, 2011 Share Posted May 16, 2011 mine stood a year and has gone the same played with yellow relay work fine over night blow window fuse in morning and windows not working changed fuse windows work but roof not .if i fined will post Quote Link to comment Share on other sites More sharing options...
Guest cabby5288 Posted May 1, 2012 Share Posted May 1, 2012 hi i have same problem my car was stopped for over a year and the roof stopped working but when i press the switch there is a relay that clicks by the pedals but the i can open the roof and close it if i use the relays in the boot. can any 1 help thanks Quote Link to comment Share on other sites More sharing options...
