Guest Savage Posted April 22, 2011 Share Posted April 22, 2011 As a lot of you know, I'm doing scumrun ths year, and now tring to stock up on improvements for next years run already. The sound system I'm happy with for this year, but I want something really kick-ass for next year. I'll ty and give as much info as possible as at the moment, but a lot of it is still planning, not yet bought / scrounged. The new sound cabinet is being drawn up (car now a 2 seat escort cabriolet with cabinet where rear seas used to be). In theory I'm looking at (rear): 3x12" Subs one bridged, (centre) with left and right audio channels (sat immediately behind diver / passenger). All 3 subs running 1000 peak / 250 RMS 2x8" Subs - direct Left and right audio sat just below where rear headrests should be. both 800w peak / 200 RMS 2x6x9" - not sure if there will be any benefit in using these - rear facing up behind driver / pass head rests. 250 peak / 70 RMS All the subs seem to be listed as 4 OHM Front (need to source,so guidance appreciated?) 2x 4" mids, & 2x4" tweets So what I want to know is, whats my best amp setup? is it bridge a lot from a couple of amps (what power?) or run seperate amps for each stage? If seerates, I assume some sort of RCA / remote splitter set will be needed or a hub of some sort? And whats my best options for fronts? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
