badger Posted April 15, 2011 Share Posted April 15, 2011 hi people i seam to be having trouble with my clutch pedal rachet system i fitted an uprated clutch to my mk4 zetec conversion last summer and everything was great (even done 1000 mile trip and 3 laps of nurenburgring) but after winter hibernation it seams to be not working right so i changed the cable for a new one and the pedal takes up the slack by clicking 1 tooth but whilst driving it seams to slip back resulting in me having to double clutch everytime..... has anyone had this problem or know of any fix's Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 15, 2011 Share Posted April 15, 2011 hi m8, how ya bin? is the clutch ratchet worn? thats a commen prob wiv this anyway & u myt ave a few teeht worn or missin, the only way 2 know is 2 pulll it off & ave a propa look m8 hop this help's, its the only thing i can think it 2 b, unless sumthin as bent? regards mark Quote Link to comment Share on other sites More sharing options...
badger Posted April 16, 2011 Author Share Posted April 16, 2011 i've had another play with it today and it is well and truly FUBAR i need to get one before friday does anyone know if ford still do them??? i'll look on ebay and pray someone will send next day.. also anyone thats done one please any tips???? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 16, 2011 Share Posted April 16, 2011 The plastic red bushes wear on the pedal causing the ratchet to to slip also. Especially on uprated clutchs Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted April 16, 2011 Share Posted April 16, 2011 have you tried putting a plastic sump washer on the gearbox fork? worked for me. I just heard that changing the ratchet is a nightmare, so went for the quick fix Quote Link to comment Share on other sites More sharing options...
badger Posted April 17, 2011 Author Share Posted April 17, 2011 new quadrant ordered from ebay lets hope i get it fixed for sundays show.. Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 17, 2011 Share Posted April 17, 2011 hi ian, i have my clutch & brake peddle assemble in the shed so i'l ave a look 2moro & see if its better 2 take it all out or leave it in & msg ya 2moro eve. mark Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 18, 2011 Share Posted April 18, 2011 hi ian just bin 2 ave a look at the peddle assemble & if there's anough room 2 slide the pivet shaft out 2wards the heater matrix then it should only just b a bit fiddly!!!! 2 take out the the pivet shaft there is a circlip on the inside of the assemble 2 the right, this 1 will b the hard 1 to get out! the shaft will only slide out 2 the right... on the shaft u ave the circlip, the body assemble, nylon spacer, clutch peddle wiv ratchet assemble in the middle, nylon spacer, spring washer, metal spacer, spring washer, nylon washer, brake peddle, nylon washer, circlip (this wil b the trickie 1), peddle assemble. u'l ave 2 slide out the shaft 2 drop the clutch out, but this will also drop the brake peddle, there is a small circlip on the brake servo shaft witch will need 2 b taken off. as mine is all out of the car i cant remember if there is anough room 2 slide the shaft out. but if there isn't then it will b alot more wrk as u'l need 2 take out the whole brake assemble!! 4 this there r 2 10mm bolt's on the inside of the bulkhead & 2 on the outside of the bulkhead, 2 10mm bolt's right up behind the dash (could b 13mm), & u'l need 2 take off the steerin column, hope u dont need 2 do this, but if u do, take off all the electric's, ie indicator's ect, & 2 13mm nut's ( need a deep socket 4 these 2) & 2 13mm bolt's up underneath the steerin column & it will just slide up & off the bolt's the shaft will not slide out the other way as it has a cut out in it which is a bugger!!!!! hope this all help's m8? regards mark Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 18, 2011 Share Posted April 18, 2011 oh if ya need sum pics just let me know. mark Quote Link to comment Share on other sites More sharing options...
badger Posted April 19, 2011 Author Share Posted April 19, 2011 hi ian just bin 2 ave a look at the peddle assemble & if there's anough room 2 slide the pivet shaft out 2wards the heater matrix then it should only just b a bit fiddly!!!! 2 take out the the pivet shaft there is a circlip on the inside of the assemble 2 the right, this 1 will b the hard 1 to get out! the shaft will only slide out 2 the right... on the shaft u ave the circlip, the body assemble, nylon spacer, clutch peddle wiv ratchet assemble in the middle, nylon spacer, spring washer, metal spacer, spring washer, nylon washer, brake peddle, nylon washer, circlip (this wil b the trickie 1), peddle assemble. u'l ave 2 slide out the shaft 2 drop the clutch out, but this will also drop the brake peddle, there is a small circlip on the brake servo shaft witch will need 2 b taken off. as mine is all out of the car i cant remember if there is anough room 2 slide the shaft out. but if there isn't then it will b alot more wrk as u'l need 2 take out the whole brake assemble!! 4 this there r 2 10mm bolt's on the inside of the bulkhead & 2 on the outside of the bulkhead, 2 10mm bolt's right up behind the dash (could b 13mm), & u'l need 2 take off the steerin column, hope u dont need 2 do this, but if u do, take off all the electric's, ie indicator's ect, & 2 13mm nut's ( need a deep socket 4 these 2) & 2 13mm bolt's up underneath the steerin column & it will just slide up & off the bolt's the shaft will not slide out the other way as it has a cut out in it which is a bugger!!!!! hope this all help's m8? regards mark cheers mate i have the new part and will attempt it friday morning fingers crossed all goes well... Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 19, 2011 Share Posted April 19, 2011 Removing the driver seat make this job a hell of alot easier. Expect lots of swearing unless you have really small arms and hands! Quote Link to comment Share on other sites More sharing options...
badger Posted April 19, 2011 Author Share Posted April 19, 2011 Removing the driver seat make this job a hell of alot easier. Expect lots of swearing unless you have really small arms and hands! i think mark in bury and avril in felixstowe will more than likely hear the swearing.. i've got great big hands and even swore just getting the cable on the other day so god help me LOL Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 20, 2011 Share Posted April 20, 2011 in that case take out the passenger seat 2 ian!! lol but on a serious note gd luck m8 & dont break nothin in temper, take that break & walk away 4 10mins or so, hopefully get 2 c it soon, but u wont mine 4 a while tho, lol but i do need 2 update my pic's soon!!! regards mark dont 4get let me know if ya need any pics? Quote Link to comment Share on other sites More sharing options...
badger Posted April 23, 2011 Author Share Posted April 23, 2011 well as promised I'd report back the car is up and running on Friday i striped the clutch pedal down and all was fine (which was a good thing as the replacement segment i brought was wrong). so after much swearing and a lot of huffing and puffing i put it all back together (what a job). so i decided that today the clutch was coming out so i stripped the gearbox off and there it was a broken clutch release bearing it was totally fubar so i dropped the uprated clutch out and put back the standard rs turbo clutch. replaced everything back to where it needs to be,tightend it all up and took it for a small test run. long test run tomorrow up to Weston with Avril (must remember to take recovery details just in case lol). Quote Link to comment Share on other sites More sharing options...
