Guest samrscab Posted April 12, 2011 Share Posted April 12, 2011 hi all will keep it as least confusing as i can!!!! this is the problem i have: SWITCH SIDELIGHTS ON: side lights come on and headlights do also (headlights are about as bright as candles even though they brand new bulbs) SWITCH HEADLIGHTS ON: headlights go out and side lights stay on???? i have changed all bulbs (led sidelights) (icewhite headlights) even tried my mates bulbs out of his onion and still the same happens please if anyone could shed some light would be big help as i cant drive in the dark as cant see!!!! cheers. Quote Link to comment Share on other sites More sharing options...
RScab Posted April 12, 2011 Share Posted April 12, 2011 Check your Earth connections m8 Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted April 13, 2011 Share Posted April 13, 2011 Sounds like a wiring problem, could have a damaged wire some where, you will need a meter to check for power loss and trace back from there. Quote Link to comment Share on other sites More sharing options...
Guest tonkerboy23 Posted April 13, 2011 Share Posted April 13, 2011 Check the 2 small relays for the lights in the underbonnet fuse box as from my experience seems to be a common problem and had this on a few mk4's i have owned Quote Link to comment Share on other sites More sharing options...
iansoutham Posted April 15, 2011 Share Posted April 15, 2011 I'd change the light stalk if it were me. The internal connections are shorting out. Remove the steering cowling, turn the headlamps on and wait 5 minutes, then feel the side of the light stalk. It will almost certainly be overly warm. Quote Link to comment Share on other sites More sharing options...
Guest samrscab Posted April 24, 2011 Share Posted April 24, 2011 thanks for all the replies, its not earth ect ect looked at under side of fusebox where 2 relys for lights are and the wires have been cut and im only getting a 6v current to the lights ?? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 25, 2011 Share Posted April 25, 2011 If the wires have been cut under the fuse box there has to be other relay's for them... as other have said the seem to common problem but check the switch aswell .... Had simlar problem on my mk4 the switch and the 2 white relay's in the fuse box(wires melted underneath) Quote Link to comment Share on other sites More sharing options...
Guest ROB1000 Posted August 5, 2012 Share Posted August 5, 2012 (edited) Did you solve the issue? I have the same trouble with my 1991 cab, where is the underbonnet fusebox? Edited August 5, 2012 by ROB1000 Quote Link to comment Share on other sites More sharing options...
