f40 cab Posted April 11, 2011 Share Posted April 11, 2011 hi everyone currently striping and rebuilding cab, for last few mots my copper brake lines have had adviserys so thought i would make some new ones never done it befor so am just looking for a bit of help cutting flaring and bending, thanks for any advice on tools tequniques, and sizes, Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 12, 2011 Share Posted April 12, 2011 you will need a tool that cuts the pipe without squeezing it, and a toll that does the flared ends, not sure what there called tho! proper brake line thinggys tho! Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 12, 2011 Share Posted April 12, 2011 I always use a very fine tooth pipe saw for cutting the pipes. I have a clamp that came with my flaring kit to make sure the end of the pipe is cut square. You also need a pipe flaring kit. I bought a sealey one for £25 off ebay ages go for £25. Not the best but does the job. Decent ones cost around £100 but they are so much better. For bending the pipe i always work out were the bend is then use a suitable size socket and push the pipe around it. This stops the pipe kinking and looks neater. A tip i found is to make sure you leave the pipe protruding around 4-5mm from the flaring clamp before starting to flare the pipe. This ensures the flare is quite big and will seal properly. Not enough and you will get leaks. Too much and the flare will twist to one side when you form it which will also cause leaks. Hope this helps Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted April 13, 2011 Share Posted April 13, 2011 Hi, try a plumbing shop for a pipe cutter and a small pipe bender, with the bender it garenties smooth bends; you will get both for about £20. A handy thing is a small round file for smoothing off the edges. Hope this helps Quote Link to comment Share on other sites More sharing options...
Guest avul Posted April 15, 2011 Share Posted April 15, 2011 hi as above junior hacksaw & a fine file 4 cutting & cleanin, as there small bore pipe's they usually dont kink but take care bendin 2 b on the safe side & same as the 4-5mm stickin out the end of flarin tool. wen i replace all of mine i'm not gonna use the copper pipe as these will still corrode over time, instead i'l b usin the pipe that doesn't corrode but i cant remember the name of it, will find out tho, but it is more expensive. regards mark Quote Link to comment Share on other sites More sharing options...
f40 cab Posted July 5, 2011 Author Share Posted July 5, 2011 hi everyone quick update, brake lines now been redone just need bending and putting back on, after buying copper nickle as advised by number of people was having difficulty trying to flare the ends it was to hard and kept pushing through the tool tried 3 differnt tools. so have now done them in copper my uncle came to do them as i was struggling for time but all pipes where flared in 20min it was so easy so my advice is to do your own if you have the time and save some money but would advise using copper not the copper nickle pipes as so much easyer and a tip is to deburr it does help. let you know when fitted, thanks for the help and advise. willing to pass it on if needed. Quote Link to comment Share on other sites More sharing options...
