Guest Delboybully Posted March 5, 2011 Share Posted March 5, 2011 I noticed today that there is about an inch of water in both the rear light clusters. I have been told to remove the lights, dry them off with a hair dryer and re-fit them but with some silicone sealer around the seal. Does this sound ok. Do the light cluster have a drain hole that could be blocked? Quote Link to comment Share on other sites More sharing options...
Guest John Posted March 6, 2011 Share Posted March 6, 2011 common fault on mk3/mk4's. yes use silicon but get a anti-fungal one go to a upvc window trader they will sort u out with the proper stuff Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 6, 2011 Share Posted March 6, 2011 or try and get a new seal for them Quote Link to comment Share on other sites More sharing options...
Guest tony.rose Posted March 6, 2011 Share Posted March 6, 2011 Once dry I would clean the seal and apply vasiline or replace with new one!! Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted March 6, 2011 Share Posted March 6, 2011 I had the light clusters out and there was some dirt on a few parts of the seals, so i cleaned the seal and bodywork where the seal meets it. I dried the lights out with a hair dryer and put some silicone sealer on the seal and refittted the lights. Hopefully this will work, i cant see it not working, silicone sealer is great stuff. Most silicone sealer sold here in England has anti-fungicide in it. The most common sealer without fungicide is aquarium sealant. I have a 1993 Mk5, so i guess it a common problem on escorts in general Quote Link to comment Share on other sites More sharing options...
