Guest tony.rose Posted February 24, 2011 Share Posted February 24, 2011 Hi, don't know if anyone knows but I have fiited a new roof to my MK4 cab, but not sure how to dismantle the rear window so I can staple the new hood to it! Any help!!! Quote Link to comment Share on other sites More sharing options...
Guest jbh325i Posted June 4, 2011 Share Posted June 4, 2011 any one got info on this? im going to be doing the same thing soon. Quote Link to comment Share on other sites More sharing options...
Guest andrew xr3i baker Posted August 29, 2011 Share Posted August 29, 2011 hi. can anyone help me pls i just had a new roof fitted and i need to know how to fit the back window in the roof? Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 29, 2011 Share Posted August 29, 2011 if you had one fitted why didnt the fitter fit it? Quote Link to comment Share on other sites More sharing options...
Guest andrew xr3i baker Posted August 29, 2011 Share Posted August 29, 2011 if you had one fitted why didnt the fitter fit it? he did not know how to do it! due to its not a stander ford roof? Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 29, 2011 Share Posted August 29, 2011 dont sound like a proper roof fitter to me then lol, what a cowboy Quote Link to comment Share on other sites More sharing options...
Guest skelly9134 Posted August 30, 2011 Share Posted August 30, 2011 I did mine recently as a got a new roof but i had to cut the hole out myself. Start off by marking out were your window is going to be, on my mk 6 i attatched the window and frame to the 2 arms on the side of the window and the two straps at the top then pressed the old window (while in the frame) into the roof, I drew a chalk line around the window and then removed the window. The measure in 3 inchs in from the chalk line and re-draw a template. cut out the inner chalk line. thats your hole. To remove your old window the insruction said to just push the old window out from the inside them remove all the staples from were the window frame is attatched to the roof. This didnt work to well due to the adehsive on the window so a soaked it in hot water to weaken the glue which worked. one the glass is out remove all the staples and then re-staple the frame into the new hole, (thats why you cut 3 inchs smaller to allow ) then re-fit the glass with adhesive and the outer seal. Its not an easy job to do so good luck Quote Link to comment Share on other sites More sharing options...
