Mk4 Roof Cover - Black ??
Guest Ryan_Wales
Guest Ryan_Wales
This isnt really a 'Roof Problem' more of a question I cant seam to find the answer to. Ive got a Mk4 Cab that has a grey Tonnaeu cover but im trying to find one in Black !!
Ive found them for the Mk5 in Black but only in grey & white for the Mk4 - Does anyone know if you can get the cover in Black ?? ??
  • 2 weeks later...
Guest keegy
When i got my tonneau with the car it was a tatty grey colour with a couple of oil marks on it, i couldn't get rid of the oil marks so i decided to try and dye it, i used a black shoe cream and a small sponge,2 tubs and 5no coats later and i had a shiny black tonneau cover that looks alot better than the grey one. all for the price of £6
Guest Alanman
Where do you get this shoe cream from???
Or this dye off eBay, how does that work??
Is it leather dye or vinyl dye I need to search for?
Oh my! So many questions. lol
Guest Alanman
Just found this on eBay for £12 so I recon I'm guna try it and I can let you know if its any good.
Edited by Alanman
got my black cover, was dissapointed that it has just been sprayed black, and some grey has worn through, so im gunna give it a go painting it again, if it fails then atleast i have me grey one still :rolleyes:
let us know how yours turns out alanman
it looks ok, i like things to be perfect tho so i wont be using it as im not 100% happy lol.
sides and back are ok, just the big section in the middle that is a bit patchy, just like using a paint rattle can. looks well in the shade but in direct sunlight it shows its flaws. need to try a cream or something to get more of a even aplication on it.
how did yours come out alanman?
Guest keegy
Doesn't look too bad, but i know what you mean about the big panel showing the flaws, try the shoe cream you get a much better application, you can get it from theshoelace.co.uk heres the link
http://www.theshoelace.co.uk/acatalog/Shoe_Polish.html?gclid=CJCSnNS74qcCFQMjfAodkHBI-g
Its £2.99 a jar, the 5th item down, you may need a few jars and a few coats to get it right, you don't have anything to lose if you are not going to use it anyway.
Good luck
Guest Ryan_Wales
Cheers for the link - its tempting to get a blck one but its just weighing up the expense with the amount of use it will actually get !!
I was tempted to try and dye mine but im not to sure that I could do a decent enough job - id probably end up balls'in it up !!
