Guest Sicoleath Posted January 22, 2011 Share Posted January 22, 2011 Hi, I want to fit my 17" Alloys, but the rear O/S wheel catches the (standard) arch most of the time,the spring is fine and the arm seems to be sitting correctly. Ive considered getting heavy duty springs or just another pair of standard springs but before i do i wanted to know if this a common problem with 17's or do they normally fit ok? Quote Link to comment Share on other sites More sharing options...
Guest planetrover Posted January 23, 2011 Share Posted January 23, 2011 iirc you may have to roll the arches or grind back the lip on the inside of it.thats what i had to do to get 17's on my s2 rst with a 40mm drop on the suspension it would catch when you hit a bump in the road. Quote Link to comment Share on other sites More sharing options...
Guest Sicoleath Posted January 23, 2011 Share Posted January 23, 2011 Thanks for that, i'll have a go at grindin the lip and see what happens then! Quote Link to comment Share on other sites More sharing options...
gingergman Posted January 25, 2011 Share Posted January 25, 2011 also check the wheels are the correct offset, Quote Link to comment Share on other sites More sharing options...
