Guest richie29gt Posted January 21, 2011 Share Posted January 21, 2011 hi all just a quick 1 is there any difference in size between the rs turbo and xr3i for discs cheers rich Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted January 21, 2011 Share Posted January 21, 2011 XR3i are 240mm & RS Turbo are 260mm Quote Link to comment Share on other sites More sharing options...
iansoutham Posted January 23, 2011 Share Posted January 23, 2011 As above really. MK3 XR and RS = 240mm MK4 XR = 240mm MK4 RS = 260mm If it helps, the 260mm disc, pads and calipers are the same as Ford Sierra and Granada (calipers and pads only on Granada) with ABS or all V6 models (except DOHC 2.0 4x4 models which have the same calipers but narrower discs). You just swap sides, i.e. Escort left is Sierra/Granada right and vise-versa. Quote Link to comment Share on other sites More sharing options...
Guest avul Posted January 24, 2011 Share Posted January 24, 2011 hi ian, did think the sierra brake's fitted the escort, i'v got xr4i calipers, disc's & pads, so there'll go on my 84 mk3 will they? also bin lookin on here & frm wat i'v seen will the sierra rear brake's fit 2? obviously i'd need 2 make a caliper carrier or can u buy those? thanx 4 any advice m8. Quote Link to comment Share on other sites More sharing options...
iansoutham Posted January 24, 2011 Share Posted January 24, 2011 hi ian, did think the sierra brake's fitted the escort, i'v got xr4i calipers, disc's & pads, so there'll go on my 84 mk3 will they? also bin lookin on here & frm wat i'v seen will the sierra rear brake's fit 2? obviously i'd need 2 make a caliper carrier or can u buy those? thanx 4 any advice m8. Not sure on the rear calipers, although you definitely would want the brackets you can buy from places like Pumabuild, AutoSpecialists, etc.. for the RS2000 rear end version. The XR4i normally has 240mm brakes if MK1 so they would be the same as what you have as standard. Quote Link to comment Share on other sites More sharing options...
Guest avul Posted January 25, 2011 Share Posted January 25, 2011 ok thanx 4 the info ian Quote Link to comment Share on other sites More sharing options...
