Mk4 '89 Efi Xr3I Cab Exhausts In Ss - Anyone???
Guest jonathanjead
Guest jonathanjead
Help - I'm right in the middle of my winter show car project and have a real headache - I'm after a SS exhaust system (not manifold) but seem to be drawing a blank as all the suppliers only do ones for tintops not Cab. I've been 'told' the cab is longer so tintop exhausts are no good - can anyone advise - either on what mods are needed to say a Piper 3" SS system (what pipes longer where) or someone who makes exhausts for the cab.
Also I've been 'informed' that the cab exhaust hangers are different - is this true?
hi jonathan as far as i'm aware they are the same, as should the hangers be & i've not heard that one b4!!! the rear box i got 4 mine i'm sure was for a tin top hope it helps & i would imagine people will say the same. mark
Guest s6boy1979
Tin top and cab exhaust are the same the only diff is between efi and mfi. The efi has a longer down pipe as it includes a silencer where as the mfi does not
Guest jonathanjead
Thanks all - I think (hope) problem solved - ordered exhaust for the EFI Tin Top 3i from Piper - they are making an adjustable centre sention so any issues can be adjusted for.
Thanks for all your info - Timax and Bosal both this the tin top and Cab as the same system now - although a little more digging with QH identified the cab exhaust is (theoretically) 14mm longer in the centre section..... not much and, if true, explains why systems should fit as 1/2" isn't much to cope with.
Piper say they want me to feed back to them about the fit and adjustment so they can then list the exhaust for the Cabrio.... I'll keep you all updated
Guest jonathanjead
Where did you get it from?
Ordered it direct from Piper Exhausts (same as Piper Cams). Fingers crossed it fits, looks nice and cam will full fitting kit - bu then again wasn't cheap...
  • 2 months later...
