Guest mark escort cos Posted December 29, 2010 Share Posted December 29, 2010 Hi My mk5 cab seems to have loose door hinges and hence the door is dropping slightly lower than it should when open, if i lift the door up there seems to be play. any suggestions|??? Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 31, 2010 Share Posted December 31, 2010 tighten the hinges, line the door up how you want it at the same time Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted December 31, 2010 Share Posted December 31, 2010 tighten the hinges, line the door up how you want it at the same time if the hinges are bolted up nice and tight on the car it sounds like the pin in the hinge is worn causing it to drop.only thing that can be done to repair it is a over sized pin fabbed up for it or a replacement hinge. Quote Link to comment Share on other sites More sharing options...
