Guest Delboybully Posted December 13, 2010 Share Posted December 13, 2010 The fuse box on my k reg cabby is playing up. I have been told a new one is about £120 and a recon box is about £60. Does anyone know wher i can get a recon box. live in Hertfordshire but getting one by post is ok with me Thanks Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 13, 2010 Share Posted December 13, 2010 Failing that, does anyone know where i can a new one from that isnt a fortune. Fords quoted £370-440 Quote Link to comment Share on other sites More sharing options...
Guest Andy H Posted December 13, 2010 Share Posted December 13, 2010 hi delboybully i had the same problem about 2 months ago on ebay got mine for 40 quid but you need to make a note of the serial number which is on the bottom right of the fuse box along with the date of manufacture or if your any good at soldering you could split the box and re do any dry joints that will defo be causing the problems but bear in mind this is only a short term fix good luck mate Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 13, 2010 Share Posted December 13, 2010 Seeing as fuseboxs are a problem with escorts, if i get a used one wont i get the same problem in the future? This is why i would idealy like a recon fuse box. If i cant get a recon one or a new one at a decent price then i will have to go for a used one Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 14, 2010 Share Posted December 14, 2010 Bump! Does any1 know where i can get a recon fuse box or a new one at a decent price? Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 15, 2010 Share Posted December 15, 2010 http://www.escortcabrioletclub.co.uk/forums/index.php?/tutorials/article/25-escort-mk6-cab-fusebox-repair-fun/ or take it to a auto electrician Quote Link to comment Share on other sites More sharing options...
Guest corrie Posted December 15, 2010 Share Posted December 15, 2010 or you can send it upto me and il do the repair on the fuse box and return next post so no need to source the same fuse box. yours repaired and you know its the correct one.inbox me for a price and your location. Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 18, 2010 Share Posted December 18, 2010 Corrie, i tried to Pm you but it says you cant receive any more messages? Quote Link to comment Share on other sites More sharing options...
Guest Andy H Posted December 20, 2010 Share Posted December 20, 2010 hi again delboybully if you get a recon box it will just be a repaired box same as if you had corrie or an auto electrican fix it if you want another that you can forget about then you may as well stump up the 4 ton and buy brand new i got mine of ebay like i said but that is'nt gona sta in there forever its just till i have saved for a brand new one Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 21, 2010 Share Posted December 21, 2010 (edited) The guy fixng the car is, unsurprisingly, having trouble gettting a new fuse box for a reasonable price. He is still trying. He has found a used fuse box for £40 but he doesnt really want to go down that route. He says a new one is best but the cost is too much for me, whereas with a used box you can possibly be in the same boat some time in the near future. I mentioned about corrie (or someone else) fixing the box and he thinks this is a good idea. So Corrie (or anyone else) can you email me with how much you would charge to recon/fix my fuse box My email address is delboybully@hotmail.co.uk. thanks Edited December 21, 2010 by Delboybully Quote Link to comment Share on other sites More sharing options...
Guest Delboybully Posted December 31, 2010 Share Posted December 31, 2010 Bump Is anyone out who can recon my fuse box Quote Link to comment Share on other sites More sharing options...
