Guest dave29 Posted December 12, 2010 Share Posted December 12, 2010 hi all. whats the best way to prep and spray a bonnet.?........ i dont have a garage so i was going to put up a gazebo with sides on to make up a mobile spray booth lol. any tips to get a decent job? i dont expect it to be a spot on job as ive never sprayed with a compressor before as long as it dont look like its been shot on with a cannon lol.oh the colour is pacifica blue....... all blue cabby colour.also where can a buy a set of steel wheel bolts from? cheers guys. Quote Link to comment Share on other sites More sharing options...
gingergman Posted December 12, 2010 Share Posted December 12, 2010 id save yourself the hassel and get a bodyshop to spray it, it wont cost much more in the long run and will look loads better, and be done quicker, but if you wanna do it yourself then just make sure its fully rubbed down and prepped properly getting rid of any rust, trouble with painting outside in the winter is there is damp in the air, you wont get a good finish and it wont last if damp gets under the paint on a cold panel. also use pre paint to wipe the bonnet before sparying. wheel bolts, try ebay, there cheap on there, or if you after used ones i have a few full sets in my garage id sell. hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted December 13, 2010 Share Posted December 13, 2010 id save yourself the hassel and get a bodyshop to spray it, it wont cost much more in the long run and will look loads better, and be done quicker, but if you wanna do it yourself then just make sure its fully rubbed down and prepped properly getting rid of any rust, trouble with painting outside in the winter is there is damp in the air, you wont get a good finish and it wont last if damp gets under the paint on a cold panel. also use pre paint to wipe the bonnet before sparying. wheel bolts, try ebay, there cheap on there, or if you after used ones i have a few full sets in my garage id sell. hope this helps. i was guna have a go at spraying myself as mines not a show winner. just want it tidy.....plus im dying to try out my new compressor lol.ive got a friend who sprayed his whole car in a gazebo and it turned out great. as for the wheel bolts i was gunna buy em new.i,ll have a look on ebay. cheers gingerman Quote Link to comment Share on other sites More sharing options...
