Guest gavintwopies Posted November 2, 2010 Share Posted November 2, 2010 if you are turboing the car the xr3i loom is no use at all, if you want to go escort rs turbo you would need rs metering unit, loom, fuel pump, and the fuel ecu as well as the normal ecu if you want to go efi, you would need fiesta turbo engine, or moddify the existing engine for crank sensor, then edis4, the efi turbo loom, ecu and a few more parts Which if your going to efi turbo and dont have a starting point doing a zetec turbo is always a worthy option as 1800 can be picked up very cheap and will run on the fezzy loom and give a good healthy power return for your £££££ 160-180bhp is a common figure without pushing things very hard at all and running most of the std settings. Quote Link to comment Share on other sites More sharing options...
