Guest gibbo88 Posted October 4, 2010 Share Posted October 4, 2010 My mk5 1.6 efi is under performing and very unresponsive, foot to the floor sturggles to reach 50 and when you release the aceelerator it jutters, any ideas???? Also ive noticed a loose connection its sucking in air with no hose on it where should it go?? im no expert but its connected to the box on top which has efi on it and its the top hose with a gap in it with a nipple for a hose but nothing attached to it also is the little blue can running off top of crank case called the crank breather as struggling to find replacement part and its crackec, could that be part of problem with performance?????? Quote Link to comment Share on other sites More sharing options...
Guest gibbo88 Posted October 4, 2010 Share Posted October 4, 2010 its a 1991?????????? not 1995 Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted October 28, 2010 Share Posted October 28, 2010 That would be the problem alright. Try and compare it to another one if you can. good luck Quote Link to comment Share on other sites More sharing options...
