Guest shaggy Posted July 6, 2010 Share Posted July 6, 2010 I have just stripped and re-built a cvh turbo engine for my escort. I know the engine needs to be run in for the 1st 1000 miles and then have an oil and filter change. what i want to know is what oil to use as some people say use the cheapest of cheap, some say use mineral oil, and some say a semi if anyone can shed some light on this for me it will be very much appreciated thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted July 6, 2010 Share Posted July 6, 2010 Use 10 40 Mineral oil for the first 1000 miles. If your serious about running in the best is to change the oil at 500 miles to mineral oil again. Then at 1000 miles onto something like 15w 50 Silolene Pro R. CVH turbo engines run so well on this and don't use hardly any oil. Don't use any synthetics until it is run in. Also if you have new cam on first startup keep the engine at around 3000 rpm for 20 mins to let the cam bed in properly. Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted July 22, 2010 Share Posted July 22, 2010 i've been told to use cheap oil Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 22, 2010 Share Posted July 22, 2010 i've been told to use cheap oil you have just spent a pretty penny re building a angine WHY would you put cheap oil in it as per other thread use a descent mineral oil there is a reason cheap oil is cheap Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 22, 2010 Share Posted July 22, 2010 lol, as stated above, that is too true! Quote Link to comment Share on other sites More sharing options...
