Guest millward Posted June 10, 2010 Share Posted June 10, 2010 Help pls put my battery on charge with a trickle charger put it on and still nothing I put it on chearge whilst on me car n the rev counter goes up will there be a wiring problem or shud I just get new battery????????? Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 10, 2010 Share Posted June 10, 2010 I would recommend charging the battery with it off the car or at least disconnect the wiring from it first, then get the battery tested before reconnecting it, the battery might have passed it sell by date or there could be a wiring problem, prove that the battery is ok first then start looking for wiring problems or water getting to the electrics/fusebox some where. Quote Link to comment Share on other sites More sharing options...
Guest millward Posted June 11, 2010 Share Posted June 11, 2010 I would recommend charging the battery with it off the car or at least disconnect the wiring from it first, then get the battery tested before reconnecting it, the battery might have passed it sell by date or there could be a wiring problem, prove that the battery is ok first then start looking for wiring problems or water getting to the electrics/fusebox some where. Cheers put it on charge yesterday goin check it in a bit and hope for the best if not a will get new battery and try again Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 11, 2010 Share Posted June 11, 2010 make sure you take the 6 caps out the top of the battery and check the de-ionised water level Quote Link to comment Share on other sites More sharing options...
Guest millward Posted June 12, 2010 Share Posted June 12, 2010 Sorted it cheers got new battery it was bust put a power cap on for me amps aswell so runnin sweet Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 13, 2010 Share Posted June 13, 2010 Nice one, lets hope you have trouble free motoring now, Thanks for letting us know. Quote Link to comment Share on other sites More sharing options...
