Guest fubar Posted June 7, 2010 Share Posted June 7, 2010 i have just bort a mk4 cab which is proper mint but i cant open the bootlid i was wondering if theres a way to open the seats from inside the car instead ov mullering the lock or lid...many fanxs Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted June 7, 2010 Share Posted June 7, 2010 Mk4 boot locks are a pain in the arse to open! Keep trying! Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 7, 2010 Share Posted June 7, 2010 spray it in wd40 mate, the locks often stick Quote Link to comment Share on other sites More sharing options...
Guest fubar Posted June 7, 2010 Share Posted June 7, 2010 spray it in wd40 mate, the locks often stick cheers m8 ill giv that a bash..fingas crossed.. Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 7, 2010 Share Posted June 7, 2010 if that dont work mate then i dunno how else to get into it as the cable for the rear seat pop is in the boot, might have to drill through the lock Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 9, 2010 Share Posted June 9, 2010 If you can't get the lock working. The best way is to release the two hinges for the bootlid. Theres two nuts right at the back of the screen inside. You should then be able to open the boot from the hinge side about 4 or 5 inchs to gain access to the rear of the lock. Should be able to trigger it to unlock with your fingers. Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 22, 2010 Share Posted June 22, 2010 any joy in opening it yet mate? Quote Link to comment Share on other sites More sharing options...
