Guest buster Posted June 1, 2010 Share Posted June 1, 2010 Hi there i recently bought a xr3i 1990 1.6 I got it home and found it struggles to turn over when hot. (I now understand this seems to be a common fault)Also ramdomly cuts out sometimes on idie and runs very hot! i have taken the stat out and it ran at the right temp when i too it for a test drive I parked up and left it running and the temp gauge got high. I have tried changing the starter to cure the hot starting problem but no better! any advice to theres problems would be a great help! many thanks Buster. Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted June 1, 2010 Share Posted June 1, 2010 This problem can usually be the starter getting hot..some heatwrap around the downpipe can help that. I have had a coil overheat before and cause the same sort of thing but im guessing as yours is a '90 it will be efi and have no coil. Also make sure your fan comes on and giving the water a flush and refill could help the cooling..if it is getting really hot and losing alot of water could be your headgasket. Quote Link to comment Share on other sites More sharing options...
Guest buster Posted June 3, 2010 Share Posted June 3, 2010 iv given the cooling system a good flush and put some heat wrap on the down pipe car seems to be staying cooler and starts better still a bit funny some time at normal temp so going to get new starter see what happens then any mpore ideas welcome and i will keep thread up to date Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 7, 2010 Share Posted June 7, 2010 get a new starter not second hand and a heat sheild for it, and also do a head gasket check on it Quote Link to comment Share on other sites More sharing options...
Guest buster Posted June 8, 2010 Share Posted June 8, 2010 yeah will get a new starter as soon as i got the money and have done a head gasket test it says its all ok Quote Link to comment Share on other sites More sharing options...
Guest kazcastle Posted July 9, 2011 Share Posted July 9, 2011 i know this is an old post now but thanks guys you really helped me out with this i had the same problem car is hot and wont turn over it sounded like it had a flat battery, i knew the battery was brand new so bought a diesel starter motor and fingers crossed i think its done the trick £65 well spent!!! Quote Link to comment Share on other sites More sharing options...
