Guest s11pyk Posted May 28, 2010 Share Posted May 28, 2010 my car is an efi mk4. its not running too well at all. it wont idle properly and if you rev it a little and let off the accelerator it cuts out! i dont know what to do with it. dont wana put it into a garage for them to spend some very expensive hours trying to find the fault. anyone had similar issues, are there any common faults? thanks everyone in advance Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted May 28, 2010 Admin Share Posted May 28, 2010 You tried cleaning the ICV (Idle Control Valve) mate? Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 28, 2010 Share Posted May 28, 2010 same as paul said, icv buddy? Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted May 28, 2010 Share Posted May 28, 2010 also check air leaks around manifold, disconnect tps and try again Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted May 28, 2010 Share Posted May 28, 2010 its come about after iv cleaned the icv???? Quote Link to comment Share on other sites More sharing options...
