Guest partington333 Posted May 20, 2010 Share Posted May 20, 2010 Hi I am new to this forum I have a 1990 xr3i with a fuel problem she start's first time and ticks over and rev's with no problems but as soon as you try to drive i.e put her under load she cuts out. I thought it could be the pump but you can hear it turning on with the ignition and as i say she revs whilst stood. Any help would be apprecated thanks. Quote Link to comment Share on other sites More sharing options...
Guest BAMBOOCHA Posted May 20, 2010 Share Posted May 20, 2010 Does the engine sounds normal and smooth while its on neutral? And if u hit the accelerator fast does it revs right away or it takes time and feels like its about to go off but then picks it up? Quote Link to comment Share on other sites More sharing options...
Guest partington333 Posted May 20, 2010 Share Posted May 20, 2010 Does the engine sounds normal and smooth while its on neutral? And if u hit the accelerator fast does it revs right away or it takes time and feels like its about to go off but then picks it up? Hi yes it sound normal whilst in neutral and revs as it should. Quote Link to comment Share on other sites More sharing options...
Guest Alanman Posted May 20, 2010 Share Posted May 20, 2010 I could still be the pump. I had one similar, you could here the pump and it would fire but as soon as you tried to drive it it cut out. It had lost all its pressure. Quote Link to comment Share on other sites More sharing options...
Guest partington333 Posted May 20, 2010 Share Posted May 20, 2010 Sorry to sound thick but is the fuel pump in the tank also can i access it under the rear seat or do i have to drop the tank. Does anyone know how much and where i could get a replacement from? Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 20, 2010 Share Posted May 20, 2010 efi engine yeah mate? the pump will be in the tank Quote Link to comment Share on other sites More sharing options...
Guest partington333 Posted May 20, 2010 Share Posted May 20, 2010 Do I need to take the fuel take out to get a the pump of can it be a accessed from under the rear seat? anyone any idea of the price of a replacement? Quote Link to comment Share on other sites More sharing options...
