Guest diggy Posted May 17, 2010 Share Posted May 17, 2010 Well folks i was on my way back from fitp when my car started to make funny noises when changing and gearing down.The sound was a loud whining noise and after asking a couple of opinions gearbox came up a few times so it looks like i will be replacing it and as i have never done one was wondering just what i'm letting myself in for so any info will be greatly accepted. diggy Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 17, 2010 Share Posted May 17, 2010 Sounds like the main shaft bearings are breaking down. Its not that difficult a job. The main things that will cause you grief are bolts that are seized and removing the gearbox once unbolted. On a drive with axle stands your looking at around 6-7 hours with some help. If your lucky enough to have a lift it will take around 3-4 hours. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted May 17, 2010 Share Posted May 17, 2010 just checked my oil level which is very low would this contribute to the problem? Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted May 17, 2010 Share Posted May 17, 2010 (edited) It's a piece of piss to change, if you have abs it can be a pain in the ass but in the end its just more stuff to take off. If you take the rollbar off the gearbox will drop out on its cradle. The shaft bearing has gone in mine and that is rattling in neutral then with the clutch in stops making a noise. It was dry and that was grindy noises followed by the odd clanking noise which went after filling it up. I did think the rattling was the thrust bearing so changed that just to put it all back together and it was the shaft bearing all along. Whack some gear oil in it and see if it changes can't hurt if it's dry. Ceased bolts probably will be the worst bit of it. Edited May 17, 2010 by RobMk4TwinCarb Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 17, 2010 Share Posted May 17, 2010 defo get some oil in there, before my old one blew up it leaked alot of oil and when it got quite low it whined like a right bitch, then topped it up with oil and it was ok, it did finally blow in the end tho lol Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted May 17, 2010 Share Posted May 17, 2010 thanks guys i have topped the oil up will give it a run in a bit and hopefully it will be ok failing that i will torch it and buy a new one with the insurance money...... only kidding! Quote Link to comment Share on other sites More sharing options...
Guest Soggyllama Posted May 17, 2010 Share Posted May 17, 2010 Took me and a mate 2 days to remove an RS2000 Engine and gearbox, and put the replacment in, the time consuming bit was connecting up all wires and cables. But with the engine out and fault finding, took about an hour to remove the gearbox, change the clutch and put the gearbox back on the engine. Probably no help to you though unless your removing the whole engine. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 17, 2010 Share Posted May 17, 2010 If your oil is low then you probably have a leak. Check both driveshaft seals. The other seal is inside on the main shaft. You'll have oil all over the clutch and oil around the bottom of the gearbox where it joins the engine. Probably best to top up and keep an eye on it Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted May 18, 2010 Share Posted May 18, 2010 ok people am i being thick or do you put oil in the gearbox seperatly from the engine? I have topped my engine oil levels but heard you have to top up the gearbox oil. Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted May 18, 2010 Share Posted May 18, 2010 yea there should be 2 plugs on the gearbox, (if my memory servs me correctly) the one higher up for filling and the one lower don for the level, take both of these out, start filling the top one untill it comes out of the lower one, ( there might also be a drain on there too, leave that one alone;)) Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 18, 2010 Share Posted May 18, 2010 Theres a hexagonal bolt on the 3i/rs gearbox facing frontwards. Undo that and fill until it starts to come out. Make sure the car is on reasonably level ground. Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted May 18, 2010 Share Posted May 18, 2010 (edited) Undo the top plug which is an 8mm hex key(on mine anyway apparently they can be torx) fill it up until the oil is less than 10mm from the top but more than 2mm use a bit of wire bent to get a level. The plug is on the gearbox at the front the top one will be round with the allen key bit in the middle and the bottom one will have a nut shape with a long bit protruding off it. Edited May 18, 2010 by RobMk4TwinCarb Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted May 18, 2010 Share Posted May 18, 2010 Tried to edit this bit in but wouldn't let me, Make sure you put gear oil in and not engine oil as you were asking where to put it, didn't want you putting engine oil in the gearbox. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted May 18, 2010 Share Posted May 18, 2010 nice one chaps there are so many people who have helped and would like to thank you all! will give it a go in the morning and fingers crossed it solves the problem. A friend has told me this happened on his car and was sorted as soon as he did it. Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 25, 2010 Share Posted May 25, 2010 whats the latest then mate? Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted May 25, 2010 Share Posted May 25, 2010 well i put it off due to being let down on stands so now i'm doing it monday. My father in law as been good enough to help me and let me have the use of his garage which is a biggy so not knocking him.Just sorting a clutch out at the moment and looking to do both at the same time! Quote Link to comment Share on other sites More sharing options...
gingergman Posted May 25, 2010 Share Posted May 25, 2010 cool mate, yeah makes sence to do the clutch at the same time, just make sure its aligned up properly! are you still driving it in the meantime lol? Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted May 25, 2010 Share Posted May 25, 2010 give me a ring if u stuck can b over to u in an hour m8 ,, weekends free at mo lol Quote Link to comment Share on other sites More sharing options...
