Guest batdan21 Posted May 7, 2010 Share Posted May 7, 2010 hi all having a little prob with the cabby and not sure what it could be so after some advise. what it is is i can get reverse when engine is cold (first thing in morning) but when the engine will reach normal tempreture i try to get reverse but all i get is grinding and wont engage? also notice whilst driving today i'm putting cluth to floor to change gear not sure if it has always been like that or wether its my mind playing tricks on me thanks to anyone that can give advise Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 7, 2010 Share Posted May 7, 2010 Look at some other posts on here this has been covered many times before. Quite a common problem. In Basic Check and replace ratchet on clutch pedal if required. Check and replace clutch cable if damaged. Release bearing on clutch may have broken down. New clutch and bearing time. Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted May 7, 2010 Share Posted May 7, 2010 Look at some other posts on here this has been covered many times before. Quite a common problem. In Basic Check and replace ratchet on clutch pedal if required. Check and replace clutch cable if damaged. Release bearing on clutch may have broken down. New clutch and bearing time. What one is the most common problem do you know? Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted May 7, 2010 Share Posted May 7, 2010 sounds like a clutch fault to me that were i would be going. Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted May 7, 2010 Share Posted May 7, 2010 thats what i thought as if it was the cable or pedal wouldnt it be all the time? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted May 8, 2010 Share Posted May 8, 2010 check clutch rachet that would be 1st thing i would check the teeth normaly wear and won't adjust other than that the clutch is shagged Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted May 8, 2010 Share Posted May 8, 2010 (edited) What Mk is this refering to? Edited May 8, 2010 by Feeble Quote Link to comment Share on other sites More sharing options...
Guest batdan21 Posted May 10, 2010 Share Posted May 10, 2010 hi all its a mk4 Quote Link to comment Share on other sites More sharing options...
