Looking For Electric Rof Relays
Guest BAMBOOCHA
Guest BAMBOOCHA
Hi everyone.
Im looking for 2 green electic roof relays which r in the boot. Does someone mayb has them for sale? Or know any place where I can find them?
Many thanks.
Guest s6boy1979
Hi everyone.
Many thanks.
I may have one but will check but i do have to 2 that go behind the dash if they are of any help?
Guest Lee81
You can buy them from any motor accessory shop. There just 30amp switched relay. Take the old one with you so you can make sure the pin positions are the same. There are a few types. They won't be green though
Guest BAMBOOCHA
I was checking all shops no one has them. I have 5 spin one and all spins has diffeent amps. 86 87a 30 85 and 87.
  • 2 weeks later...
Guest BAMBOOCHA
Thank u guys 4 looking up 4 them. Was trying 2 zoom images but unfortunately cant see any numbers or amps so I will write down what is written on mines then and if they match plz let me know. =)))
Ok first picture my 1 says:
Ford G1UHK
V91AB-L13A025-AA
V23134-E52-X167
12V 40/35A
3EA
And 2nd picture if u put relay in that position amp says:
Left-87
Top-85
mid-87a
bottom-30
right-86
Its 5 pin, The position of pins on the green one looks absolutely the same as on mine, just need to be same amps. Plz check if they match.
gingerman 5pounds sounds good! =)) I have PayPal.
Thank you.
Guest s6boy1979
My green one, the numbers on the top don't really match only the 12v 40/35A but the pins are spot on
Guest BAMBOOCHA
I dont think its matter, what matter is that the pin amps should match. =))) Keep it safe m8 just want 3 wait if gingerman has some. Cheers. =))
both mine are green and the pin amps match, but depending on what way you look at it, your saying
Left-87
Top-85
mid-87a
bottom-30
right-86
mine say that but if you rotate it round so the amps are the right way up mine are the other way, ie top 30, bottom 85, etc, you sure you looked at it the right way?
and sorry if that dont make too much sence, its getting confusing lol
Guest BAMBOOCHA
Left-87
Top-85
mid-87a
bottom-30
right-86
Hi, thx 4 looking.
I was reading them according to the position of relay in 2nd picture of s6boy1979 post. Yeah and If u turn it other way than its shows what u r saying! I think they r the ones! =DD Do you have a PayPal? =))
Guest BAMBOOCHA
you got em yet mate?
Hi,
sorry for late response was away 4 a while! Yeah I have got them cheers mate! =)) But the other day was loading my boot and somehow broke the plastic side of the pump and all liquid is gone, so now need to look for new electric pump. bad luck with this roof fixing business!!! =DDD
