Guest cod Posted May 3, 2010 Share Posted May 3, 2010 my 1990 xr3i efi wont start got a very weak spark ive changed the plugs & leads,coil pack & camshaft sensor still no luck any ideas? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted May 3, 2010 Share Posted May 3, 2010 Hi cod you got fuel? check the pump button in spare wheel well hasnt popped up....other than that it could be crank sensor.....but not to sure Quote Link to comment Share on other sites More sharing options...
Guest cod Posted May 3, 2010 Share Posted May 3, 2010 hi shaun its got fuel & had new crank sensor thanks 4 ur help Quote Link to comment Share on other sites More sharing options...
RScab Posted May 3, 2010 Share Posted May 3, 2010 If you've got Fuel & a spark It has 2 b timing try swapping sensors for ones you know that work. also check all your earth cables m8 if these r all OK cud be ECU Quote Link to comment Share on other sites More sharing options...
Guest cod Posted May 4, 2010 Share Posted May 4, 2010 hi checked all earths timing belt not broke didnt really want to go down the ecu track as mrs moanin about costs again any other suggestions any advice appreciated Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted May 4, 2010 Share Posted May 4, 2010 Was it running ok last time you had it going ? have you tried towing it just to see if it will fire up ? is the starter ok, ie not lazy turning engine over. Quote Link to comment Share on other sites More sharing options...
Guest cod Posted May 5, 2010 Share Posted May 5, 2010 car was running sweet then she splutterd a couple of times put clutch in she reved up fine then when let clutch out she died, wiggled a few wires & plug leads she started & got me home now wont start tried tow starting engine is turning over but just wont fire up, starter is spinning as it should, cleaned all earths coil pack & craddle,cleaned plugs again still nothing Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted May 5, 2010 Share Posted May 5, 2010 welcome to cabbyland! i hate mine so much i love it! mines efi. il end up replacing everythin and with the money iv spent probably could turbo it. but it is a labour of love and there will always be something! enjoy. hope you get it sorted tho! Quote Link to comment Share on other sites More sharing options...
Guest cod Posted June 12, 2010 Share Posted June 12, 2010 should be getting the cab back from the garage this week turned out the petrol tank was blocked causing the coil to over spark & burn out Quote Link to comment Share on other sites More sharing options...
