Guest jasseb Posted April 17, 2010 Share Posted April 17, 2010 Hi all any help greatly appreciated just put the engine (1.6 cvh) back in mk4 cab, having trouble with one of the breather pipes everything is connected but can't see where the long pipe that comes off the top left of the the rocker cover, across the front of the engine bay connects to ?? Any help would be great as this is the last one to connect but can't see where it goes !! Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted April 17, 2010 Share Posted April 17, 2010 dose it not go onto the air box. Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 17, 2010 Share Posted April 17, 2010 dose it not go onto the air box. thanks will have a look Tom cheers Quote Link to comment Share on other sites More sharing options...
chaz Posted April 18, 2010 Share Posted April 18, 2010 If you are still not sure put a pic up it will be easier to identify. Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted April 18, 2010 Share Posted April 18, 2010 hi mate is your engine efi or mfi ? as ive got a standard cab with mfi engine in i can let you straight away Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 18, 2010 Share Posted April 18, 2010 dose it not go onto the air box. Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 18, 2010 Share Posted April 18, 2010 It's the mfi mate Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 18, 2010 Share Posted April 18, 2010 It's the mfi mate hi mate the long pipe goes to the top off air box Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 19, 2010 Share Posted April 19, 2010 Thanks mate will have a look tonight Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 20, 2010 Share Posted April 20, 2010 Found it thanks for all your help Quote Link to comment Share on other sites More sharing options...
