Guest Pierce Posted April 7, 2010 Share Posted April 7, 2010 starts first time but if you try and rev it it just dies it seems like not enough fuel or to much air can't hear it sucking air Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted April 8, 2010 Share Posted April 8, 2010 have you checked filters plugs? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 9, 2010 Share Posted April 9, 2010 check dizzy cap and leads maybe rotor arm.....or as lee said check air filter and plugs Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted April 10, 2010 Share Posted April 10, 2010 its not long had a service was running fine then just started playing up changed map sensor TPS and air temp sensor Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted April 10, 2010 Share Posted April 10, 2010 If I disconect the air temperature sensor it will tick over but still struggles to rev up as soon as I reconnect it it starts to die I have changed the sensor but still the same Quote Link to comment Share on other sites More sharing options...
Guest richie29gt Posted April 10, 2010 Share Posted April 10, 2010 check ur pipe from inlet to brake servo and c wot happerns when u take it off Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted April 10, 2010 Share Posted April 10, 2010 If I take the pipe off the tick over goes up if I plug the hole it goes back to how it was. I'm doing this for my sister she just told me this satrted about half an hour after she put some petrol in I'm thinking it coul be dodgey fuel Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted April 11, 2010 Share Posted April 11, 2010 do you think it could be the ECU Quote Link to comment Share on other sites More sharing options...
Guest smarty Posted April 25, 2010 Share Posted April 25, 2010 Check the fuel cut off switch in the boot, i had a dodgy connector on mine,same symtom. Quote Link to comment Share on other sites More sharing options...
Guest dazzy16 Posted April 25, 2010 Share Posted April 25, 2010 As smarty says, check the fuel cut off, mine did exactly that, so i bridged the wires, been perfect ever since Quote Link to comment Share on other sites More sharing options...
