Guest jasseb Posted April 7, 2010 Share Posted April 7, 2010 Thanks for any help in advance, I'm in the process of putting my rebuilt mfi engine and gear box back into my cab but I can't seem to get the speedo cable out of the gearbox housing I've removed the roll pin but it won't budge, any help greatly recieved thanks Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted April 7, 2010 Admin Share Posted April 7, 2010 Should just unscrew mate, think its a 22mm nut Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 7, 2010 Share Posted April 7, 2010 yeah as paul said it should be a 22mm, Quote Link to comment Share on other sites More sharing options...
Guest jasseb Posted April 9, 2010 Share Posted April 9, 2010 Not sure if it unscrews basically the threaded end is sticking out of the gear box and won't move at all Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 9, 2010 Share Posted April 9, 2010 Not sure if it unscrews basically the threaded end is sticking out of the gear box and won't move at all should just pull up out of the box......you can use a pair off mole grips to grab the speedo drive but be-carful not to tighten grips to tight. hope this helps Quote Link to comment Share on other sites More sharing options...
