Guest StarLoc Posted March 28, 2010 Share Posted March 28, 2010 Weve whacked the dipstick tube.... only a bit but hard to check the oil, how does the tube come out of the block? is it screwed in?, pressed in?, it seems to turn round a bit,i just dont want to break it, i have an unbent one on the old engine want to change it over ( unless i have to strip the engine down ) How does it come out? Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 29, 2010 Share Posted March 29, 2010 what engine is it? 1600 cvh just push in, altho its quite a long tube and may be a bit of a sod to get out Quote Link to comment Share on other sites More sharing options...
Guest StarLoc Posted March 30, 2010 Share Posted March 30, 2010 Its the 1600 cvh , the tube seens to turn quite easily so hopefully it will pull out , i didnt want to try pulling if there was a thread on it thanks Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 30, 2010 Share Posted March 30, 2010 they do turn easy, its quite long tho and think it curves on the way out, but will be ok to pull it! Quote Link to comment Share on other sites More sharing options...
