Guest markjaide Posted March 27, 2010 Share Posted March 27, 2010 hi just brought a f reg xr3i cabby today went to the shop and left the engine rnning as i walked away i heard a whinning sound and the engine cut out then i couldnt start it for about half hour the petrol gauge before this was on full then it went to just above empty and started any one no wat this is??also i have to fight it to change gear??its recently had a new hood fitted and have to push the windows aswell as the door to get it to shut properly else theres a gap is it just a poorly fitted hood??thanx Quote Link to comment Share on other sites More sharing options...
Chris Posted March 27, 2010 Share Posted March 27, 2010 The cutting out sounds to me like your fuel pump relay or pump is playing up(relay is the pink/purple one under the dash drivers side).. It may be over heating and shorting out. Can you here the pump prime (buzz when you turn the ignition?) By fitting do you mean its reluctant to go into gear or to stay in gear?.. this could be down to a few things but id start by checking the cluth cable.. need more info Roof wise you can adjust the windows on there regulator to get them to track up to diffrent hight but other wise its a pretty common cab folly Quote Link to comment Share on other sites More sharing options...
Guest markjaide Posted March 27, 2010 Share Posted March 27, 2010 The cutting out sounds to me like your fuel pump relay or pump is playing up(relay is the pink/purple one under the dash drivers side).. It may be over heating and shorting out. Can you here the pump prime (buzz when you turn the ignition?) By fitting do you mean its reluctant to go into gear or to stay in gear?.. this could be down to a few things but id start by checking the cluth cable.. need more info Roof wise you can adjust the windows on there regulator to get them to track up to diffrent hight but other wise its a pretty common cab folly okok ok ill have a look at the fuel pump relay i can hear the pump buzz when i turn on the ignition?it sounded more like a fan belt screaching altho im sure the noise was coming from the drivers side rear wheel ? as for the clutch its reluctant to go into gear you have to be really forcefull to find the gear and get it to in sometimes it goes in easy sometimes not? thanx for your reply Quote Link to comment Share on other sites More sharing options...
Chris Posted March 27, 2010 Share Posted March 27, 2010 fuel pump is indeed just up behind the rear wheel arch.. just check it for a good constant 12volts when its running Quote Link to comment Share on other sites More sharing options...
Guest markjaide Posted March 27, 2010 Share Posted March 27, 2010 fuel pump is indeed just up behind the rear wheel arch.. just check it for a good constant 12volts when its running ok both battery terminals were loose ive since tightend them should i wait to see if it does it again or get it down to the garage tomoz? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted March 28, 2010 Share Posted March 28, 2010 hi mark i would adgree with chris have simaler problem on mine and if i bang fuel pump it starts so would go for fuel pump....try it 1st with terminals tight.... good luck maye Quote Link to comment Share on other sites More sharing options...
