Guest Suede Posted March 14, 2010 Share Posted March 14, 2010 Hi mates. I have a question; is it possible and "easy" to replace the clutch without removing the engine on a XR3i -88? Does any of you have a description how to? I have experience of clutch work on rear wheel drive cars and that what quite "easy", but no experience of the Escort. From a snow and cold in Sweden/ Suede Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 14, 2010 Share Posted March 14, 2010 hello mate, yes you can replace the clutch leaving the engine in the car, its not to hard Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted March 19, 2010 Share Posted March 19, 2010 I have done my clutch with everything in the car last spring and then again to change the thrust bearing about 2 months later (crappy ebay part). I undone the rollbar and both bottom arms, supported the engine and undone the gearbox cradle, dropped the gearbox and cracked on. Well it wasnt quite that easy stupid abs modulators can be a pain in the arse. It's a bit tight getting it back on but there is room. Quote Link to comment Share on other sites More sharing options...
Guest Suede Posted March 22, 2010 Share Posted March 22, 2010 Thanks mate for the advice, it does not seems to be that hard to do this. Yes tight but I will give it a try. /suede Quote Link to comment Share on other sites More sharing options...
