Guest poshchatterbox Posted March 2, 2010 Share Posted March 2, 2010 hello please can some one help me out with my little problem, i finished work on monday in the lovely sun and decided to go topless, but when i pressed the button to put roof down, nothing, no sound of motor, no movement of roof, just dont know if motor gone, or has it got a fuse on it, not very tech with cars, any help would be grateful Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted March 2, 2010 Share Posted March 2, 2010 Hi posh welcome to cabbie land .......check relays got power and check pump is getting power Quote Link to comment Share on other sites More sharing options...
Guest poshchatterbox Posted March 2, 2010 Share Posted March 2, 2010 Hi posh welcome to cabbie land .......check relays got power and check pump is getting power thanks for advice, i will get hubby to check the tech side of it, as i dont know where the relays are but i do know where the pump is, and then hopefully i can get my baby aired in the sun Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted March 2, 2010 Share Posted March 2, 2010 Hi posh the relays are green and there is 2 of them.you can put roof down manualy by turning the T on top of pump let us know how you get on Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 3, 2010 Share Posted March 3, 2010 theres a couple of relays under the dash and there should be two more next to the pump, also test the switch for it, swap it over with electric window switch to see Quote Link to comment Share on other sites More sharing options...
